On the right track software, i just cant seem to find bridges or turntables!
Can anyone help me?
That would be dependent on the library you have selected. Go to the command bar and select “element”. In the drop down window select “Load Library”.
I am guessing you have the HO scale code 83 library called up. You will find the bridges and turntable in the HO scale code 100 library.
