I recently acquired an Atlas S-2 that i was looking into installing DCC for my brother’s layout. Does anyone have a wiring diagram or explanation as i cannot understand how the wiring works in the light board?
Thank-you in advance,
Colin
Colin
This is the newer HO scale.
This is the older version that is a little harder to do.
Pete
Colin:
Another option for the Atlas/Roco units is the NCE S4 decoder. It is a rather easy install and has a provision for the rear headlight. The install requires the same insulation steps as the TCS decoder. A critical step in either installation is the replacement of the motor screw with a nylon or delrin one.
Joe
