Atlas SD 24 shell removal??
What is the correct procedure for removing the shell from an Atlas SD 24?
not sure on sd24, but with atlas it is usually the couplers pocket screws, remove them and above each truck is a plastic tab, apply inward pressure and wiggle back and forth until it comes off, some come right off and others are quite stuborn.
