On an Atlas manual snap-switch is the throw housing removable. I would like to remove it for it is rather bulky and use some type of small ground throw instead. Thanks for any input.
If I remember correctly, there are just a couple of small screws. I can’t imagine that they have changed their design, it has been a long time since I looked. The manual throws are the same size and shape as the powered ones, which makes them easy to change out.
Actually, if they are the common type, (code 100) you should just be able to pry it off the track peice. Also, depending on how many switches ro tracks you have, sometimes the extension tab can get in the way. It is flipabble You can disconnect the track guieds (or the things that move that are the track) and put in on the other side.
Hope that helps…
Best regards
John kanicsar
Perhaps bending a paper clip would work. Notice the hole in the center of the switch throw. With the switch throw centered (even gap between rails) mark the center of the third tie towards the frog, being sure it is in the center position and is directly in line, now position throw so that a train would go straight through. The alignment mark will be to one side, the move the throw to the other position, the alignment mark should be equal to the other side. Only after equal movement to both sides do you drill it to the size or slightly larger than the paper clip.
Bend a paperclip 90 degrees on both ends, with approx a 40 degree sharp bend between both ends. Ya may have to make a few of these to get it right. One 90 degree will be longer that goes in the solid tie, shorter one in the movable throw, be sure of clearence under throw. Dont force it as it may have to be adjusted a tad, it should have a light but forcefull throw to both sides, if it only throw to one side the original marks for the hole was not centered.
You now have a spring loaded turnout like a Pico. cut the long turnout selector off and mount a fake switch stand, move the turnout by pushing the point of the turnout. Or trim the throw to what you desire for the stand. Use black marker on your new clip spring.
Hope this helps…John
There is an article on the NMRA ‘Introduction to Model Railroading’ pages called ‘Installing a Caboose Industries Ground Throw’ http://www.nmra.org/beginner/ground_throw.html that addresses just exactly that.
Yes, the twin coil is easily removable/replacable, I just replaced one the other day.
scada
