I’m making a vote for the Atlas Trainman GP38-2 and Athearn GP40-2 Ready to roll. Also, you can post tips, pros and cons, and other advice with your vote. I’ll post my own opinions later on in the thread. Happy voting!
Like I said earlier, I would post my own opinion. I’ve ranked them based on my own first hand experance.
-UNDER BODY ASSEMBLY: Atlas GP38-2; the can motor of the Atlas is of high quality. It’s fuel tank is of correct size and shape for the railroad, and has internal, screw-on wieghts for added traction. Also included in the motor is a printed-circut board, making easy to add DCC and has directional lighting. The only other thing that I would add to the Atlas is to replace the incandesent light bulbs to LEDs with contant lighting if DCC is not used.
-SHELL BODY: Athearn GP40-2; I have to say, the Ready To Roll line of GP40-2s are nicely detailed compaired to the Atlas. They have proper engine access doors, (which are one of the best representations I’ve seen!) factory-assembled grab irons that are in-line and square, window and number board gasketing, (which doesnt seem to make such a difference to the average modeler, but can spice things up quite a bit) and nicely done, crisp lettering a numbering on the shell. The only complaint that I have for the Athearn shell is it’s number boards; they’re inverted. The numbering is black, not white. The number board itself is the opposite and reverse of the real number boards.
-CONTROL/POWER/OPERATION: Atlas GP38-2; in this case, I have to agree with the Atlas. With a printed circut board, 5-pole skewed wound amature found on the master line locomotives, and quitet, smooth operation, the Atlas is a 1st prize winner. The weights also make a difference in the operatoin of the loco, giving added weight and added traction. With already wired connection from the motor to the trucks, a better connection is present. With the Athearn, it’s merely a sliding metal piece that is on all older Athearn kits (NOTE: most modelers snap off the sliding metal contact and solder it with flexable wiring; I’ve done that and it does inprove operation). Also, the moto
Is there any way to put the atlas motor on the athearn frame? I mean, the atlas frames has different trucks, fuel tank, and details from the real CPR GP40-2. Also, anybody have any ideas on if I can put the atlas interior in the athearn?
I would go with the Athern GP40-2 R-T-R. The Atlas Trainman GP38-2 is more expensive. You can find the GP40-2 at first hobby for $67. The Athern has more details. My [2c]
The best way is to mount the GP40-2 shell on the Atlas drive by grinding the weight down.A Dremel tool will work…Of course by the time you buy both locos-a Trainman GP38-2 for the drive and the Athearn GP40-2 you would be better off buying the Atlas GP40-2 for $99.99 discount.
