Got yet another one for my Forum friends. (Warning this will get a bit long-winded.) I am the technical advisor to our local museum in rebuilding a destroyed rail yard diorama. (I’m the only model railroader of the bunch and famous or infamous in town for having a large model railroad.) I had been working on the display for a number of years before it was damaged. The wood base was warped beyond repair due to a roof leak a couple winters ago and it had weak spots before that anyway. (The building is not heated during September to April as museum is closed.) The issue with the roof has since been fixed.
What would be the “best” way to attach track given the following conditions: All flex track except for turnouts with some curves but mostly straight, non-powered rail (Display is static with no practical way to power the rail), attached directly to wood that has been painted to look like cinder ballast to match the era of the display, the possibility of “easy” removal in case of future damage to display (I hope it never happens again but it is wise to plan ahead) and the unheated building. (It has some A/C during the summer.)
The old track was attached with track nails but they were hard to remove from what I was told (I was not involved with that aspect of the process.) and some track was damaged. (More track has been ordered to have onhand for replacement as needed.)
I’m leaning toward using the chaulk method that I have read about but I’ve never used it or even seen how it works, especially with flex track. I have also thought about using a different type of nail. (Something closer to a 1/2" or 5/8" household nail which is what I have used for my own layout except with 3/4" nails.)
As a mural is going to be painted on the back wall of the display space before the track is replaced and none of the prep work has happened yet, I figure it will be next year before the track gets reinstalled so this is not an immediate need.
As
