What do you mean by “lines?” Gaps around the hood doors, raised edges to the paint finish, or?
Removing the flags sounds like a tricky job if you want to preserve the underlying factory yellow. Would it be possible to decal over the existing flags, or is the shape/size/underlying texture off enough that it won’t work? You may be able to cut the decals into pieces and use them to fill in. I’ve had pretty good success using a very small brush to paint around lettering gaps in situations where a full repaint wasn’t desired and decals wouldn’t necessarily have worked. Keeping excess paint under control is a must though.
It may be a plan to mask and then grit-blast the flag and numbers off the models (if you can get access to somebody who has a blaster) and then repaint the affected areas. Otherwise careful use of a sanding stick (i.e. a narrow strip of sandpaper wrapped around a the beveled end of a piece of stripwood) may do the trick.
The paint stamp of the flag did not cover portions of the shell around the cabinet doors. There are vertical stripes of Armour Yellow around the cabinet doors.
I’m trying to avoid removing the Armour Yellow paint; sanding/blasting is hopefully an option of last resort.
Are there certain solvents that would be ‘less aggressive’ in removing only stamps/decals, and not the underlying Armour Yellow?
I looked at photos on the Fallen Flags site. the vertical lines appear to be white on clean (freshly painted) locos but grey to almost black on weathered locos. I also looked at photos of the model. It appears a grey wash to accenuate the lines would work.
Nice eye Martin and thank you for the link. I thought the lines on my models were a quality control issue. The devil is always in the details. Great pics for weathering and appliance detail placement.
Any ideas on a specific product that can remove the Athearn number paint without damaging the underlying Armour Yellow?
