Auto Racks
I saw a UP train today pulling a long string of auto racks. There was a box car between the lead engines and the auto racks. And there was a box car between the auto racks and the locomotive on the back of the train. What is the purpose of this arrangement?
It may be a variation of the buffer car on oil trains but for a different reason. Because of the long coupler shanks on auto racks and intermodal flat cars, lateral forces on curves can become a problem, especially since locomotives have gotten longer. A short wheelbase car may be able to reduce these forces.
I may be off base so a little help would be appreciated greatly.
I just did a cursory look through UP’s System Special Instructions (most recent version, May 2016), and can find nothing concerning separating auto racks from motive power. In fact, it could be counter-productive, snce trains made up exclusively of auto racks are entitled to higher speeds on lines where the freight-train maxium speeds allow.
I can’t see a reason to put a buffer car on a train of auto racks, since they have to be broken apart and unloaded through the ends of the cars. Unlike with the unit ethanol or crude trains, something’s got to give!
Is it possible that the auto racks were empty and if the boxcars were full they could serve as extra brakes?
Yes, the auto racks appeared to be empty.
Auto racks have proper braking power - loaded or empty.
Back in the day of the open multi-level auto carriers, the B&O ran a hopper car with a high, ice breaking appratus at the head end of trains that handled automobiles.
back in the day PRR/Conrail always had a 50’ box or reefer between auto racks or Pig Flats and the caboose if being pushed out of Altoona. This was done to help with coupler angle issues in buff.
I’ll bite. What is coupler angle issues in buff?
Buff forces are where the slack within the couplings has been compressed. If drawhead design permits ‘excessive’ angularity when being compressed - bad things can and do happen. A rear end helper is attempting to shove the slack into the train as the head end power is attempting to pull the slack out of the train.
The pulling force is known as draft, the pushing force is known as buff.
Here a follow-on auto rack question?
I saw an auto rack train on the BNSF that had some auto racks that were nearly fully enclosed and appeared to have three levels. Two of the units are permanently coupled together, I presume, because they share a truck in the middle.
The cars were marked BNSF, OAK, and Kansas City Southern. Are these a new type of auto rack or have they been around for some time?
This train did not have a box car between the lead locomotive, and there were no locomotives at the rear of the train. The auto racks appeared to be empty.
Those are Auto Max articulated cars.
Automax are unique in that they are integral and not racks on flat cars.
If you’re a conspiracy theorist, those are the FEMA shackle cars for covert movement of political prisoners…
…regardless of the fact that you can see cars in them…
About a year or two ago there was a discussion about why intermodal stack cars were articulated in odd numbers, (1, 3, 5), and the answer was that standard brake rigging was set up to handle pairs of trucks, making it desirable to have even numbers of trucks. How are the brakes rigged in the paired autoracks?
Let me add a little to this ‘in context’ – even if the drawhead design is good, if you have those long TrailerTrain style pig flats, with the trucks well inboard of the ends, the coupler ‘buff faces’ (largely the outer part of the knuckles, a few inches from the pulling faces) will be far outboard of the centerline of the track. When actual buff force is applied, this produces a significant component of lateral force which will ultimately try to force the ‘outside’ flanges on the adjacent truck harder against the side of the railhead, and may ultimately contribute to flange wear, flange climb, and other very real contributors to derailment.
Balt knew all this, of course; he just didn’t say it explicitly.
One further point about drawhead angularity: permitted coupler swing is necessarily greater on those long flats in order to allow the coupler to be moved to where it will couple to an adjacent car on a curve in the first place. If there is no good centering alignment arrangement in buff, the lateral buff force I mentioned will continue to push the coupler head laterally to a further angle, in part determined by the play between the coupled pulling faces when the couplers are in buff, before all the swing is taken up and the buff force is exerted laterally on the car center sill or other structure.
Start by looking at Dick Dawson’s post (and some of the others) in the thread I think you’re referring to, which explain some of the relevant reasons, both engineering and economic.
Here is a PDF from Wabtec that covers some of the brake-rigging arrangements circa 2004.
These are them! What are the advantages of these cars compared to the more traditional auto racks?
Come to think of it I did see one or two nefarious characters peering out of one or two of the openings. Or maybe there were three or four of them. Tune in tomorrow. I’ll bet I can get it up to five or six. And by the end of July my imagination could work it up to a whole army of aliens.
If these cars are used to carry people, why do they not have full-width diaphragms?[:)]
People in shackles are not going to be responding to chimes to go to the dining car, or heading to the lounge for happy hour.
