So I set, in order, CV31=16, CV32=2, and CV403=32. The prime mover STILL does not start up automatically once power is applied to my NCE PowerCab system.
EDIT:So I googled it, and apparently you have to set the following CVs in order: CV31=16, CV32=2, and CV419=32. It’s NOT CV403 like in the stupid damned ESU manual to turn on the sound automatically. Ridiculous.
I put a loksound select in an Atlas and sound started when power was applied to the PowerCab (not a command to the loco) I didn’t like that and discovered that F8 was mapped as not F8. I believe I solved that by making F8 …F8 again. I didn’t see an explanation of what “not F8” means or why you would use it.
The default maps F8 to the sound “prime mover”, therefore, F8 needs to be ON to enable the prime mover sound. By setting the CV to the logic of “Not F8” it means the prime mover is on when F8 is not on.
One thing to remember is that since EVERY key and EVERY sounf and EVERY function wire is completely reconfigurable, and also there are 2 logic settings for each function (hence the hundreds of CVs to handle every possible case), there are endless combinations. All settable by the person who creates the sound project.
So - the manual is NOT wrong - the manual is correct for ESU produced sound projects. Each OEM using the decoders can set up their sound projects however they want. The only ones who can accurately document this is the OEM who made the sound project in the first place. ESU’s manual can give you a starting point, and certainly all the CVs that are fixed (but not necessarily the default values for those CVs). It would be nice if everyone made their sound projects the same, but complain to the OEMs, not ESU. Plus you have a wide variety of models. ALl have the basics, but then you start adding features like an extra rotary beacon, ditch lights, independent number boards, or class lights that can correctly display off, white, red, or green. With 29 functions there are plenty of keys to activate all this but outside of standard US practice of making F0 the headlight, F1 the bell, and F2 the horn, all the rest are up for grabs and the OEM can map any key they want to any feature they want.
I will first say that I am not an expert on this. However, I went through this with a friend recently and it was CV403, not 419. Assuming that the decoder in question is a Select, there is a FAQ on the Loksound website that discusses this, and tells how to have the sound on at power up, as well as sound off at power up
