In a recent email newsletter from Loy’s Toys, Loy Spurlock discussed the use of automatic transmission fluid for track cleaning. He reports that it cleans the rails and doesn’t leave an oily film and the effect is long lasting. Has anyone tried this? Loy also announced his retirement. It will be sad to lose the high quality Loy’s Toys source for DCC products.
I would really be concerned about using ATF, as it will suck the base oils out of plastc(like your ties). ATF was once popular for striping plastic shells, but they tended to become quite ‘brittle’ after being striped. Remember, plastic IS a petroleum product…
I think you may have confused ATF with brake fluid. Brake fluid has alcohol in addition to other components. The alcohol was generally considered the paint-stripping agent, and could “leach” some plasticizers out of the plastic.
Automatic transmission fluid (at least since 1990, and much earlier I believe) is specifically designed to be plastic compatible. Modern transmissions have many plastic internal components, and ATF is designed to lubricate, cool, and serve as a hydraulic fluid to transmit power inside the transmission - all without being renewed or changed for several years.
ATF is very “clingy” and doesn’t dry out, which makes it very good for lubricating model locomotives. These very properties argue against it being an effective track cleaner. Although ATF has “detergents” in it that would dissolve the dirt on the rails, its “clinginess” would make the oily film next to impossible to remove (contrary to what the OP stated). Most effective track cleaners have components that evaporate quickly (alcohol, acetone, etc), thus leaving the rail dry after the residue is wiped. I am willing to be shown I am wrong, but ATF would be the last chemical I would consider using to clean my track.
You are right - I was thinking of ‘Brake’ fluid. And I still would not apply ATF to the track. I have used lacquer thinner applied with a TTX track cleaner(that meters the fluid out very well). This way there is no excess ‘slop’ to get on the ties and ‘melt’ them. And the lacquer thinner leaves no residue!
At a NMRA-TLR open house last week I cleaned all of my trackage with lacquer thinner applied with a Tonys Train Exchange CMX track cleaning car - very effective. I only had to use the ‘Brite Boy’ on a couple of sections where paint/scenery work was done. I have used the ‘chrome polish’ method, but it is just too much work! I spent maybe 25-30 minutes total to clean over 450’ of track.
Many types of automatic transmission fluid will attack plastic, with the exception of Dexron/Mercon. It’s made for GM vehicles which have transmissions and/or transaxles containing plastic parts. Also, brake fluid has been used as a paint stripper.
Dexron / Mercon III has been recommended as a lubricant for models, but not for track cleaning. We use Dexron at our club to lubricate locomotives and it seems to be doing just fine.
I’m wondering if maybe the use of Dexron for models got twisted around before the news reached Loy?
Ditto on any oil product. At various times I’ve used them all, Wahl’s, Color TV tuner cleaner, eraser products, alcohol. I’ve gleamed some of my track and that works well, but is time consuming. The other night I cleaned some with 91% alcohol and finished it with 2-26. I noticed this morning this method was tried by someone on another thread. I was surprised how much cleaning I had to do to get all the black off and have the rails wipe clean. So, it might not be that much less work or quicker than gleaming.
I tested the cleaned track with a Toby the Tram Engine, with DCC, sound and lights and Percy. They tend to be very picky about dirty track. Both worked well with out even the faintest flicker of light or hesitation. I then applied the 2-26, let it dry and re-checked. Same good results. I’ll be interested to see how long it lasts without cleaning or wiping down.
Is this where the expression "well lubed’ comes from?
The concern about traction tires is a valid one. Some of the rubberier types (neoprene?) swell and fall off if they become oil soaked, and it’s not going to do anything good for traction overall. Alcohol or glass cleaning products do a very good job of degreasing and cutting through dirt.
I was visiting a friend about 2 weeks ago and he was showing me his huge DCC layout. I noticed a lot of the staging tracks were almost impossible to get at, as well as there being a lot of hidden track. Naturally my first question was “how on earth do you clean your track ?”. He told me ATF and I just about choked.
He explained that somehow the ATF reacts with the dirt etc. and makes it conductive - I didn’t believe a word of it, but since I use ATF at work, I thought I’d give it a go.
My layout in my dirty garage hasn’t been used in 2 years and the grime build up was phenomenal. So I break out the ATF, but a blob on a rag and wipe the rails. I also used an abrasive track cleaner on a piece of adjacent track to at least give the locos a known piece of clean track to run on.
The results just blew me away. For the first run over the dirty track, I could hear this incredible noise of something serious going on between the rails and the wheels - but no arcing. The locos made it over, albeit a bit slower than on the clean track.
For the second and subsequent runs, it was like the track was never dirty.
My friend reckoned that for existing clean track, all you need to do is wet a q-tip with ATF, spread it over a couple of inches on the track, and this keeps the entire track work clean for weeks - he’s never had a dirty track issue at all.
His layout sees constant use - don’t know how mine will fear in another 2 years when I use it next !
This was an article in the May 2011 MRR mag. It was well done as a controlled test over a long period. The bottom line to the article was that for mainlines, ATF was the best for keeping trains running. I personally would first use synthetic ATF as it would not leach out the petroleum aspects of plastic. I also use Mobil 1 as a lubricant for the locos, etc. I think 0/20 weight, maybe 0/10. I refill the old needle containers with it Synthetic lubricants are generally less affected by temperature and have a clinging property.
I, too, have a garage layout so dust is on the tracks and the trains can sit for a few weeks between runs. My two Bachmann steamers, DCC Soundtrax decoders, stuttered, lerched and jerked to a halt following a very thorough cleaning of the rails. I read many forum posts, here and elsewhere, about oil on the tracks. Reluctantly I applied a few dabs of Lebelle 108 oil, started the steamers and to my astonishment, they run perfectly! Now, time will tell if I have made a mistake or if I cured a dirty track problem.
