All of the above are excellent ideas and suggestions.
I’ve built several craftsman type kits over the years and while they are challenging they are best approached by taking one step at a time. Don’t look at the final product and feel that it might be beyond your skill set.
Read the entire set of instructions from first to last so you can get an idea of what will be happening during each stage of construction. Organize all the parts/pieces and then go back and carefully re-read the first paragraph and go to work. Don’t get rushed and remember that wood glue does take a little time to form a reasonably solid bond. Work for a while and then let things sit while you do something else. You’ll also need several blades for an X-Acto type knife as using a dull blade will cause endless frustration along with uneven cuts.
If staining is required it is best done prior to construction as any glue residue on a wood surface will easily be seen after staining. In fact glue, for the most part, won’t take a stain. So you might stain some wood pieces, let them dry overnight and then begin construction the following day.
