Bachman’s Emily is loosely based on the Stirling Single UK locomotive. I got some parts from back2bay6 that helped me quite a bit. I’ve already sanded off the molded boiler bands and covered over it with Nashua Metal Duct tape(don’t use the Walmart stuff, it’s half as thick!). I’ve added bolt heads from Ozark castings also. Cut off the back of the cab so it is straight across.
This view shows the wheel behind the open holes in the ‘splashers’. Note the bolt heads on the front. Castings I got also have cylinder covers for the cylinders with bolt heads molded in and full backhead parts.
