Bachman K4s disassembly
I was asked by a friend to fix his K4 and I can’t even begin to disassemble this piece of junk. I need to get the first set of drivers out and have removed the two screws between the sets of drivers. What do I need to do next to get the bottom retaining plate off? Nothing else is visble and I didn’t feel a screw in the bottom of the stack. Thank you.
You may have to pop some tabs. I’ve taken their Consolidation apart and the plate was held in place by small tabs. Be careful as they are small. Gently squeezing the sides in may help the process.
Fergie
