bachman shays & climaxes
hi i’am installing tsunami 750 decoders in these loco’s with leds for the lites to work i what caps or resisters need to cut out of the circuit on the lite boards or would it be better hard wire the decoders in.
My Spectrum Climax came with LED headlights already installed. I just plugged a decoder into the 8-pin receptacle.
these has bulbs in them
Negitive…
The shay has 2 bulbs and the Climax has LEDs.
Unfortunately, these are NOT easy installs as space is at a premium in both units.
David B
ok the climax would be basicly an easy install. the shay would be a real bear to install a decoder as for the lites i bought some flat leds and iam going remove the lens in front remove the bulb then drill a hole in the rear housing and run wires down under the bottom of the frame to decoder and try to figure how to hardwire it the only problem i see is trying find out which wire goes to what since they all the same color. it time get out meter.
