bachmann 2-10-0 dcc sound
I have a recently purchased bachmann 2-10-0. The engine runs fine and all the sounds work. But the light barely lights up when I turn on that function. I have other bachmann DCC steam engines and they all have bright headlights. Could this be a problem with a 'CV that needs to be changed or is it more likely an electrical problem that I will have to go to bachmann about. All help will be greatly appreciated.
wdcrvr
If it is a yellow LED it is much more dim than the older ones that used bulbs…
I have a habit nowadays to replace all of the OEM lights with warm white LED´s with higher brightness.
Also the Bachmann Decapod uses a plastic light tube from the boiler to the headlight to emit light from a bulb inside. best to eliminate that tube and place a bulb directly in the headlight casting.you 'll need to replace the plastic headlight casting with a metal/brass detail part…not hard to do.
