I have one of the subject locos [cab 1836], which is dead as a dodo & not responding to wires held direct to the wheels.
It has 1 ‘tyre’ on the front left wheel [when looked at from the front] . Should there be 2 tyres?? 1 seems odd.
Where does this loco pick up the power from. ie, which wheels??
Thanks
Tanked
Addendum:
Loco is HO scale & manufactured in Hong Kong
Tanked
Maybe this link will give you an idea. If you do not have a multimeter, you should get one. That way you can do a continuity check.
http://www.thetrain.org/locomotives/262.htm
You might find some answers here.
http://www.hoseeker.org/otherhotrains.html
Thanks for links.
In the end I found one of the problems was mechanical - the axle on which the bull gear sits had split under one of the wheels and the wheel could rotate on the axle, which was throwing valve gear timing out the window.
Tanked
