Bachmann 2-8-0 with DCC/Sound (Changing Whistles)
I would like to know how to change the whistles without the proggraming track.
Your system should have an Ops Mode of programming on the main. Make sure that is selected from your programming options. Then, make darned good and sure the loco you want to fiddle with is the one active on your throttle…check once more.
Once in Ops Mode, find the CV to change whistles, bell rates, whatever, and then enter a value from the table in the manual. Are we not talking about a Tsunami variant? In any event, consult the manual for that decoder and merely follow the steps.
Search the forums for a thread called “Tutoral Decoder pro” and follow the directions. It will tell you what CVs you need to change and what is available to you on the Tsunami-Bachmann variant.
David B
Never mind this post. I don’t need any more info.
Thanks,
Luke
