It says “allows the operator total freedom by integrating advanced infra red wireless technology into an affordable and powerful Digital Command Control System”
What does this mean? You have to point something like the older tv remotes?
I’ve never seen a Dynamis system used by anyone, so take my comments with a grain of salt. Everyone I know around here uses NCE, Digitrax, or EasyDCC radio control systems. We use NCE radio throttles at our club, and I use the same system for my home layout.
By all means, follow Rich’s advice and read up about the system before purchase, especially sites with information provided by actual users, and not the ones who have posted on Bachmann’s or M. B. Klein’s web sites – they may be Bachmann employees. The ‘technical specifications’ provided about the system on the Model Train Stuff site is the advertising copy provided by Bachmann.
Infrared simply means “line of sight.” You have to point the controller’s infrared beam at an infrared receiver in order for the command to be recognized by the system. If there is any obstruction between the transmitter and receiver the beam will be blocked.
Their advertising says “Wide angle receivers” but makes no mention of potential range (distance from receiver). Infrared light tends to rapidly disperse and weaken. Some fluorescent lighting also emits quite a bit of infrared light, which could potentially cause interference. Infrared also implies that the receiver has to be mounted in a readily visible, elevated location in order to receive the IR signals, so it can’t be placed out of sight under your layout.
My opinion is that it would be a little cumbersome to handle, requiring two hands. What if you need to have one hand free to manipulate rerailing or couplers?
Seems to be a little pricey, even from M. B. Klein, for what you’re getting, but it is made in Germany by Elektronic Solutions Ulm, the makers of LokSound decoders.
In Europe, it sells under the brand name “ECoS” so you may be able to find some good information by searching for that name. Keep in mind, though, that Dynamis is a very anemic, wa
Dynamis is a cut-down ESU ECoS - it looks the same but they left out some of the expansion connections. What expansion options they do have for Dynamis get VERY expensive VERY quickly.
IR is line of sight, yes like the TV remote. The other thing is the handheld part of the Dynamis is larger than the throttles available for the more mainstream DCC systems.
Do consider one of the mainstream systems, you will have a more capable AND expandable system for not a whole lot more money. Bachmann seems to have no DCC strategy - the EZ Command is made by Lenz and is a very dumbed down DCC command station, along the lines of the orignal DCC from MRC, and then they have Dynamis. There is no expansion path, the two systems are made by different OEMs and are not compatible (other than they both put NMRA DCC packets on the rails). They are like MRC a few years back - MRC’s first 3 or 4 systems each were not compatible witht he previous one, so you had to basically toss the old one and start over. They finally learned with their current lineup. Digitrax and NCE have always had solid upgrade paths.
Penny wise, pound foolish are these dead-end systems.
For some reason, seeing “wireless” i was thinking RF, from handheld(throttle) to base? Pretty much brainfart on my part.
Ive only got a small room(9x15) for my layout, (which im not to happy with…theres just not enough space for what i want to do...) but i know i want wireless DCC. I will probably go with the NCE system, heres one in stock-$588
Agreed. Tell us more about your layoput. Scale? Size? Number of trains you expect to run at the same time, number of operators.
If the Dynamis was going to be enough, surely the Zephyr or PowerCab will also be enough. Both are fully expandable, no part left behind, if you later grow your layout and needs. I started with a Zephyr almost 13 years ago, and have since expanded with more throttles and an extra booster.
I began with the E-Z Command system with a D/C controller MU’d. This was a great transition from analog (D/C) to digital (DCC). Because of a feature built into the E-Z Command system it fooled the analog locomotives into thinking they were running on an analog system. There are limitation on runtime and you don’t want to let an analog loco sit idle- -it will fry the motor.
I added a 5-A power booster to this system because I tend to run consists and needed a little more oomph.
Then came the day I needed to access higher CV functions. I did some research and decided that the Dynamis system would work for me.
Because I had the Bachmann components already it was plug ‘n play.
I lost the ability to fool analog locos into thinking they were on a D/C pike.
Yes the handset is a line-of-sight device. I mounted the receiver on the wall above my layout in a location where the devices can communicate. There are no obstructions; support pillars, etc.
The one drawback to this system is that you cannot read CVs. You can write them but not read them. For that you need The Pro decoder. For now I don’t need that function.
I bought all of this on eBay. Everything that I bought was new in factory sealed packaging complete with warranty cards. I paid about half, or less, of what Bachmann lists on their website.
It all gets expensive no matter what route you choose.
The Dynamis is a good fit for me.
One word of caution- -you’ll need to buy some good quality AAA rechargeable batteries. I have two sets that I leapfrog. The cost of replacing batteries for the handset can get expensive.
