Just bought 1 of these, and it is slow as a snail at full speed, when compared to my 5 other loco`s(3 bachmann diesels,mantua goat,bli cabforward) all DCC.
It does say under product description “scale speed gearing”…
So, is this normal? anybody got one?
Don`t hear any bad noise from it,guess i was expecting it to go a little faster though
I don’t have a Climax but I do know that the real ones were not built for speed. Quite the opposite. They were designed to pull heavy loads on steep grades around tight corners on tenuous track. They also had to contend with innumerable drive shafts and gears, all of which would probably have destroyed themselves at high rpms. The last thing the operators wanted was speed.
Fast is not in the 1:1 Builder’s discription, the Bachmann 50 tonner is right up there in speed with those MDC Roundhouse boxcabs and that strange looking Climax thing from the same manufacturer of ages ago. Sometimes you get tired of waiting for the things to get where there going.
They look way better when running on track with lots of curves as opposed to track that is straight.
Scale top speed of around 15 mph or less is to be expected.
FYI –
The 50-Ton 2-Truck Climax has a plastic gears splitting issue. Because of the split gear problem, Bachmann started producing the Climax with metal gears. Using the Bachmann Product Item Number, look it up to determine if your Climax has metal gears. If it does not have metal gears, order them from Bachmann Parts while they are available.
