Does anyone know if it possible to change the speed tables on a Bachmann E-Z Command decoder? I’m trying to match speeds with another locomotive equipped with a Tsunami Soundtraxx decoder and would prefer to change the speed table on the Bachmann unit.
According to Bachmann, you should be able to change CV29. Maybe this will help…
http://www.bachmanntrains.com/home-usa/ez_content/1_Amp_Decoder_Instr.pdf
Not that I’m aware of.
We really need to know what model Bachmann decoder you have. The documentation in that web link indicates that model decoder only selects 14/27 or 28/128 speed step operation. Also one can set the starting voltage, but not the mid or max voltage. I suspect there is a ‘built-in’ speed table, but it appear not to be accessible by the user. This is pretty much the ‘norm’ for older low end decoders. I am aware that at one point Bachmann was using a low end Lenz decoder in their engines, but I am not sure what non-sound decoder they are using currently.
Jim
