Can someone tell me the wheelbase of the Bachmann Gandy Dancer hand car? I’ve run into a bit of a problem in that I’m kitbashing a Bachmann Brill street car body into a 1903 Brill combine with a full interior. The baggage section scales out at 7’-9" ( or about 1-1/16"). The NWSL PDT that I bought for it many years ago is way too big as is the original Bachmann motor/power truck. Before I go and scratchbuild my own drive, I’d like the dimensions of the Bachmann Gandy Dancer hand truck.
Kindest regards,
Alan Mende
In case you do not get an answer here, you can also ask at the Bachmann forums. Many users there with Bachmann reps.
Google Bachmann forums for link.
Alan. I just measured my Bachman Gandy Dancer. It is 6’ 0” wheelbase.
Another alternative might be the Stanton drive from NWSL. I have one in my repowered Bachman doodlebug . It has a 7’ 0” wheel base .
Thank you, Garry. I’ll have to see if the motor – minus the figures, etc. – will fit in the baggage compartment. I have a Stanton drive powering an old Aristocraft CNJ boxcab, and it, too, is too large.
Alan
Alan:
Interesting project! I love working with tiny drive systems. Unfortunately I don’t know of any drives that are less than 6 scale feet in length.
There is a modeller on the forums who is a bit of a genius at designing and building small drive systems. His forum name is Darth Santa Fe. You might want to send him a PM to see if he has any suggestions. He is a great guy and a superb modeller, and he is quite willing to share his methodologies.
Dave
I think it will be hard to get a motor powerful enough to actually pull the thing and small enough to fit between the axles, with gears, in a less than 6 scale foot length. However, if there is room to go vertical with the motor, or some sort of remote mounted motor, with a belt drive (say parts from late model Bachmann steam locos with cogged belts - those old spring belts used in brass models work as long as you don;t want to pull some traielr cars, but they are noisy). Don’t know any available ready to go though. Dave’s got the best bet, check with Darth, he builds all sorts of intricate drives for his projects. One thing, with a vertical motor there can be issues with the torque trying to twist the truck to one side or the other, making it prone to picking switch points and frogs. SO it’s not all roses - there are tradeoffs.
