Bachmann GE 44 with Sound
Has anyone succeeded at putting a decoder with sound in the Bachmann GE 44? With decoders for N & Z scale so small, I would think that a sound decoder might fit in the '44.
I am a novice at this, and am trying to plan for the future of my layout and rolling stock.
Blaine
Loksound Micro.
David B
The decoder will fit, but where are you going to put the speaker?
Its a press fit to the top of the cab roof. I just installed one. Not a big deal at all…
David B
David -
Any pictures available of that install? Which speaker did you use, and what sounds?
TIA,
Paul
Use the speaker that comes with the micro, give it a small baffel and press it into the top of the cab.
David B
David,
Could you provide more detail regarding the baffle you used or point me to another thread? I understand the concept, I’m less sure of the exact execution. I’m using this decoder right now in my project on an S3
Thanks,
Mark
http://www.westportterminal.de/video/Kadee_magnet.wmv
Wolfgang Dudler published a great and highly detailed article on this in Scale Rails a few months back. Scale Rails is a great reason to belong to the NMRA. The speaker was mounted, as I recall under the motor, he removed the weight to make room.
Joe Daddy
This topic came up a little while back. It had some interesting links and input.
http://cs.trains.com/forums/1422083/ShowPost.aspx
To my knowledge Wolfgang is the first to pull this off.
