Bachmann ho scale sound value help needed
Hello i have a sound value gp7 it was running great then i unplugged it came back later powered up the sound worked but the engine did not move.then after reversing it a couple times the engine sped down the track uncontrollable so i took it off put it back on the track .sound,lights ,horn,bell,all work engine does not move . i use a bachmann ez command dcc controler. i unplugged it and put on a dc power supply engine works fine sound works as it should in dc mode. any ideas what the problem is ?
Set CV29 to NOT run on analogue (DC) power, to prevent runaways like this.
I have read this in a few other DCC forums.
