You need to use compatabiity mode (or whatever it’s called) with the latest version of Internet Explorer. That’s why we can’t see what you’ve typed.
Yes, Tsunamis run very hot. Do you have any ventilation at all, assuming you mounted it in the tender? You might try cutting some plastic out of the floor of the tender to let some more air in.
Hopefully someone can help. I bought a Bachmann K4 today and after fixing the solder short on the circuit board in the tender I fitted a Soundtraxx TSU 1000 and 8ohm speaker. Tight fit, but after some surgery it all went in. Ran fine for about 3 minutes until the decoder overheated. I then taped the flat side of the decoder to a metal weight in the tender to help cooling as recommended in the installation guide, still over heated. I then ran without the tender body on for max air circulation, still overheated.
Surely the motor draw in these K4s isn’t too much for a 1A decoder?
Send an e-mail to Soundtraxx support. I had a bad Tsunami, basically bad out of the box. We swapped e-mails and they suggested things to try, but finally they said to send it back and they replaced it. They’re very responsive.
It’s an 8 ohm speaker, 22mm x 58mm x 9.3mm so fairly large. I did try turning the volume down yesterday and that didn’t seem to help so I discouted that idea. At your suggestion I have just muted the sound completely and it did over heat.
I have also just tried running this decoder, sound on in another loco and it went round and round quite happily with no problems, put it back in the K4 and it over heated. Hmm, loco issue??! Now back in the first post I did mention before I could run on DCC I had to fix a solder oops on the underside of the PC board. It was pins 4 and 5 where the solder joints were merged so left rail was going directly to the left motor, glad I found that before I smoked the thing! Anyway, could some continued voltage leakage be causing the excessive heating up? It’s certainly a messy solder job on this board.
You could just rip out the board and connect the TSU 1000 directly to the motor and track wires and avoid any chanceof there being a problem with the circuit board. I suppose it’s possible that if there is only liek one strand of wire bridging the connections then not enough current woudl get through to actually fry the decoder but would cause problems. Since a test shows it doesn’t draw excessive current then it’s not a motor issue - although a motor with a bad winding can cause spikes in the current draw that you might not see with a digital meter, and unless your stall test catches iton the bad winding, it won’t show an excessive draw there either. But seeing as how there already was an issue with the circut board, I’d start there. The decoder’s been proven to be ok, so no problem there, either.
Interesting idea Randy, so what is the purpose of the PCB anyway? Here’s showing my electronic ignorance! There’s a bunch of black things, 2 little copper coils and a few brown/silver looking things. I can identify the wires leading to it, rail left, rail right (conveniently labelled L and R), then I’m guessing M+ and M- are the + and - motor terminals. The last 2 must be the headlight then I’m guessing…
I’ve had as close as look as I can and I can’t find any more potential crosses on the PCB,and I’ve checked the resistance where I can and can’t find anything obvious.
I have to agree with Randy on this. When I do an instal I normally remove the locos factory boards and wire in the 9 pin JST harness directly to the decoder and replace the lights with LEDs and resistors. Sometimes the extra circuits on the factory boards can have adverse effects on decoder functions. This becomes especially true if the factory board is set for directional lighting and I want the lighting to work in either direction. It also has the advantage of adding additional space to an already cramped space.
The circuit boars houses capacitors and inductors to cut RF interference (and incidently mess with smooth DCC operation), as well as a bunch of diodes for directional lighting (not needed for DCC - they get bypassed when you plug the decoder in anyway), and possibly also dropping resistors for the LED headlight and backup light, which are simple enough to add yourself when ahrdwiring the decoder.
Uness thre is a wierd design, such as the circuit board being the only obvious way to keep things away fromt he moving parts, I withotu fail completely strip out the factory boards from any loco I put a decoder in and wire directly to the track and motor. Sometimes factory boards have a mistake, which causes no problems on DC but can fry a decoder. Sometimes the factory boards need lines cut anyway to work with DCC, so why bother? And sometimes the facotry boards are full of needlesly complex junk that isn;t even used in a aprticualr model (the P2K E units and FAs with the transistor circuit to alternate the dual filament Mars light - even on models that do not even have a Mars light, somes to mind here). Also those hokey plastic clips to hold the wires on - even if the board stays, I always solder those, the clips either loosen up or have stray bits of wire hanging out which may or may not short things. I generally replace all incandescent lights with LEDs, so there’s relalyno reason to make the lighting connection removeable - the LED will outlve my grandchildren (should I even have any). The decoders I use all have a 9 pin plug so if somethign should happen to the decoder I can swap it without cutting any wires. Or even connect a dummy plug to convert the loco back to DC.
Well, sounds like it could be time to say sayonara PCB then! Just one question, if I keep the existing headlight, do I need a resistor? If so what rating? I’m not sure if this loco has a bulb or an LED and no idea how to get at it!
Not sure when I’ll be getting to this, the working week beckons and I think I should upgrade my soldering iron from the cheapo Home depot thing too.
The latest K4 Spectrum I have came with an LED for the headlight and that one is about 8 years old. I imagine yours is the same. You can wiggle the boiler front off very carefully and see it just behind the firebox door. I use a 1K 1/4 watt resistor with all the LEDs I use. I find that this value works good for the various track voltages my locomotives encounter between friends layouts and the clubs layouts.
Exactly. If there’s a backup light, you need 2 resistors. Doesn;t matter which wire the reistor goes in, but it does matter which wire hooks to the blue decoder wire and which hooks to the white (for headlight) or yellow (for backup light). However, if you get it backwards, no harm done, the LED just won’t come on.
Ok, I took out the PCB and soldered in the decoder. Firstly I was very pleased to find I managed to solder all the connections properly (I am a very novice solderer). It ran ok for a while, but then the decoder overheated again[:'(]
I’m going to contact soundtraxx today. I was wondering why then did it work ok in my other loco, the only thing I can think of it the position I had it in that loco was in direct contact with the chunky loco metal chassis so I may still need a heat sink in good contact…
