In the Bachmann Mogul 2-6-0 “Emma Nevada” there’s supposed to be a "plug-and-play"socket with a dummy plug in it to accommodate DCC or sound modules, located in the tender. Has anyone used this socket? I can’t find it under the coal load as specified in the GR Magazine February 2017 article by Kevin Strong.
Pull out the dummy plug that is on top of the board. You can then plug directly into the board if your DCC board has a 21 pin interface. If it does not you can use the interface plug (the one with all the wires on it) to wire in a decoder without the 21 pins.
I’m old and senile. My eyes see but my brain doesn’t comprehend. I was looking for a white nylon plug. I didn’t recognize the small green board with a few electronic parts on it. Thanks Bucksco!
