Bachmann N scale Coupler Conversion
All my rolling stock is converted to knuckle couplers either accumate or MT. Got a Bachmann SD45 for my birthday. I tried to use MT 1015-1 couplers as MT’s website says is the one that should work. Works fine on the front, but on the long hood end there’s not enough clearance between the coupler MT coupler box, and the truck causing the truck to bind. I’ve ground down the coupler box and rounded the corners and it still binds. Any suggestions, only one I got was on the Trainboard. " Buy Katos".
CBandQ_guy
Have you contacted MT directly, either by phone or e-mail? It may be someone else has noted the problem to them and they just haven’t changed their on-line chart. If not, it will give them the heads up to do so, they should be able to figure it out.
Good luck,
Buy Katos…
(sorry, couldnt resist) [:P]
David B
