Thanks to Trolleyboy’s post last week, I ordered one of these and got it last night. It’s a nice little unit, and I think it will be a fine addition to my layout.
I got the Undecorated model, because I’ll be painting and decalling it to match my Moose Bay Transit Authority fleet. (Well, it will be the second in the “fleet.”) This is the first time I’ve bought an undecorated car.
It is by no means ready-to-run out of the box. There’s a lot of small-parts assembly, mostly details. It will make the trolley easier to paint, of course, because I don’t have to worry about painting around light frames and windows. What surprised me is that there was no step-by-step text document in the box, only a few exploded diagrams. Some of the parts will be tricky to identify, I suspect.
So, on to the questions:
First, for anyone who has one of these pre-painted - did you have significant assembly, or is that a characteristic of the Undecorated model only?
For anyone who has one, either pre-painted or not - Did it come with any instructions, other than the exploded diagram? In other words, did they leave something out of mine?
Finally, what is the long, thin mesh thing for? It looks like a roofwalk, but the diagram makes it look like it mounts on the left side of the car somehow.
I believe the painted models come fully assembled, like any other Bachmann engine. Undecorated models from most or all manufacturers come with the details unassembled for easier painting.
Bachmann only gives exploded diagrams with their products, since they’re usually fully assembled.
I think that long mesh is a see-through window blind, so passengers can look through the windows without having bright sunlight in their eyes. I was just on a bus last week that had them.
Thanks. That pretty much answers all my questions.
For those who are interested, the model has a very tiny slide switch on the bottom that allows you to choose either track power or overhead power. Although I won’t use that myself, I thought it was a nice thing to do for the really serious traction types.
Without having seen the mesh in question, I believe it’s a screen that runs along the bottom of the window to prevent people putting their arms outside. Lots of early streetcars had them.
I’m not sure why they disappeared, perhaps to enable escape in the event of an accident or fire.
In Toronto & Hamilton Ontario, both single & double ended cars had screens or bars on both sides. It also kept heads inside thus preventing a fatality.
Hey Mr B glad you liked the kit enought o buy one. Just to expand on that fence it was a saftey fence for most companies put on the left side of the cars. In 1921 talking TTC and Toronto the Witt’s were the first cars orderd by the TTC.Previous to 1921 Toronto’s street railways were operated by four different companies, once they were all amalgamated into the TTC the new company had a pile of incompatible cars types so the witts were the answer to streamlinning the parts department among other things. they put the screens on the left sides as the Witt’s roamed system wide but on the old Toronto railway Company lines Yonge street when it was a surface route etc , the clearances were so tight that it would have been a hazzard to have one’s arm out the window in the doubled tracked areas if another Witt was heading in the oposite direction. After the line rebuilds in the thirties the catching problem was solved as they widdened the ROW,they took the fences off in the thirties though as one of the 2400 series Witts hit a truck and caught fire , what protected people also trapped people in a burning streetcar.If anyone is interested I did a couple short posts on the TTC and it’s beginnings over on the Classic trains forum in the Our Place thread.
OK, I’ve taken another step. I loosely installed the circuit board, and plugged in the wiring harness from the chassis, plus the decoder. I programmed and read back the address, and it looks like the trolley works just fine.
This model comes with a Bachmann decoder. In the earlier Peter Witt thread, someone said that it wasn’t quite a standard decoder. I’ve noticed that the interior lights come on with the F0 headlight key, but that they are dimmed by the F1 key, normally the bell in a sound-equipped unit. I do plan to replace the decoder with sound, so I’m hoping this isn’t a problem.
Does anyone know if the interior lights are wired in a strange way, like to one of the other function outputs of the decoder?
This is a good picture set in that auction. Sadly I think the cost is either the exchange rate at work against the US dollar or a little profiteering.
Those pictures are identical to what I have seen with the Baltimore Trolley waiting for me downtown, I just hope that I can assign it an address on those bachmann decoders.
I have the trolley here at home today and it is a wonderful little machine.
The only nitpick is the string that holds the trolley pole. You can place the pole into a small metal clip designed to keep it stowed. But the thread that holds it loop hangs a bit much.
I did not yet run the thing because track is literally under construction for some time.
Perhaps a later run is comming out sound equiped like alot of their steam engines have. I’ve been all over their website, and on OSI’s and the other big sound chip makers. No one yet has announced anything. A wait and see. I hope that , concidering the quality of this model I hope that they continue on with others.
Well, mine showed up at the LHS a couple of weeks ago, and I’ve got it painted, decalled and assembled. These are home-made decals for the Moose Bay Transit Authority.
There’s a speaker and sound decoder on order. I’m going to install the new Digitrax SFX0416, which is a sound-only decoder with a couple of extra function outputs. It’s also programable, so I’m going to install a traction “sound project” that’s available at the Digitrax site. The decoder just needs power, so it should be compatable with the Bachmann decoder that came with the trolley.
I’ve still got to put the passengers inside, and install a few detail parts on the shell. I’m going to wait until the sound stuff comes in before I do that, though.
Nice paint job Mr B [tup] keep us posted on the soundchip.I’m wondering are you able to record your own sounds and then load them onto existing sound decoders. The only reason I’m asking is two fold.#1 I’m a member of the Halton County Museum in Ontario and we have three operable Witt’s that could be recorded,we also have a bunch of 33 RPM records that we have sold in the gift shop for years that the one side is a Witt car sound track and the B side is a PCC.I had heard somewhere that you could buy decoders and then add sound to them anyone no if that is or isn’t false ?
PCM Reading T1 had Nick Kulp releasing sound files in a format designed to be downloaded first onto a computer off the internet. Thence to a software app/hardware program track that is plugged into the computer.
Uploading the sound into the engine is then possible. You can replace the whistle with the sound of Pigs if you wanted to. Not that such activity is recommended.
There are too many options for the different manufactors, Digitrax, LokSound, QSI etc to explain in one post but most all of them involve some kind of computer connection; software tied to the program track to upload to engines.
For me, QSI is very easy, pull old chip and replace it with upgrade chip or… buy latest QSI factory installed engines. It is just like replacing a computer CPU on a motherboard die.
This is an assembled set of sounds. The Digitrax “Soundloader” software can be used to read the file, display the contents and play the individual sounds. This will run on a PC. It’s designed to operate with the Digitrax PR-2 programming module, which will download the sound files to a decoder. You can listen to the sounds without a PR-2, though.
