I need a backdrop that is 72" long. Does anyone make them this big. If not, what do you do. Put two of the same side by side?
What sort of scene are you looking for, and what scale are you in?
Lp
Mrfixit
I did a quick search for ‘model railroad backdrops’ and got several hits. These guys are one of the bigger companies specializing in backdrops. Their site is a little complicated ( read PITA!). From the main page select ‘Model RR’. Then select ‘INDEX’ and scroll down to ‘PRODUCTS’ to see what they have. If you see something that interests you then you can go back to the index and look through the many options and suggestions they offer.
http://backdropwarehouse.com/indexbdwh.htm
Dave
Welcome to the forums.
Have you concidered painting your own? A simple blue sky background can add a lot to a layout and is easy to do. There are a number of videos and books on painting your own. I’m about to take that step myself. I plan blue sky faded to lighter just above the horizon. Will try a few clouds. Have seen how to do simple background hills and trees, doesn’t look hard, but I plan to pratice that part first. For city or other complex scenes, if your skills are like mine, there are a number of manufacturers listed in the Walthers catalog.
Good luck,
Richard
As “hon30critter” stated backdropwarehouse.com is hard to figure out their website and expensive. I found a place in Canada called “Sceniking” they have some good stuff but only deal in Paypal of which i’m not fond of. I’m trying a place this week that i found called “realisticbackgrounds.com”. They had what i’m looking for at a good price,so I’ll see what happens.
I use the Sceniking backdrops - which are available from my local train store. They are designed to connect to each other so you can make them as long as you want:
!(http://i1212.photobucket.com/albums/cc450/YorkCentralRailway/Derry Maine in HO Scale - Part 1 - The Beginning/DerryHO_Feb2010042.jpg)
Welcome to the forums [#welcome]
As noted earlier what do you want your backdrop to be. One solution is to take your own pictures and have it printed. The cost is usually about 7 to 8 bucks a square foot on vinyl that an be placed on several different surfaces.
