Background scenery for northern Ohio (or Eastern Michigan)
I need some pictures of small town and/or rural scenery in preferably northern Ohio, east of Toledo, near Lake Erie. I know it’s rather flat there, as I have been up there before but it’s been over 10 years ago. If anyone has any photos they’d like to share so I have some idea of what to use on my backdrop as scenery, it would be greatly appreciated.
Thanks
Tom,
Sorry I don’t have any photos to share but I can offer some ideas. Between Toledo and Sandusky:
  • Any crops that northern Indiana would have - corn specifically
  • Marshes and wetlands are common
  • Petroleum refineries (Toledo)
  • Rock and gravel processing
  • Sandusky Bay
  • Houses made from limestone
  • Marblehead lighthouse
Sorry I couldn’t help more.
Google Earth and Miscrosoft Live can give you a general lay of the land. I was checking out the rail yards by Cleveland Hopkins airport the other night. You can see the type of industries in any area.
Found some sites
http://web.ulib.csuohio.edu/SpecColl/glihc/cpcindex.html
http://www.tabblo.com/studio/stories/view/112276/?nextnav=tag&tag=rainy
http://www.worldfromtheweb.com/Parks/Cleveland/Cleveland.html
I found these just by doing a search for “Cleveland Industrial pictures” You could probably substitute any city name and get the same type of results.
Having driven from Toledo to Niagara Fallsa in 1984, I recall that you are getting into the so called “Rust Belt” populated with hundreds of closed down and rusting factories a tribute to the manufacturing acumen of the Japanese.
Actually, the area I’m modeling is the semi-rural-small town area just to the east of Toledo (between Toledo and Sandusky); urban but not big city. One of the old Penn Central or N&W branch lines from back in the late 70’s. This is more east Toledo-Lake Erie theme than the very heavily smokestack industrialized areas around Cleveland or Toledo even, for that matter.
I just flew out of Detroit and over Michigan between Detroit and Toledo. (We took off facing west and did a southward U-turn to go east.) I also flew over southern Ontario. The land is primarily flat, green farmland and there were many swampy areas near the rivers. Unless someone can take panoramic photos for you, I recommend commercial backdrops like the following link.
That area is very flat and most of the horizon is going to be tree lines. i would bring the sky down almost to the ground and scrub in a tree line (oaks and maples and the ilk) about 1" high. Dry brush the trees in like doing a stencil. Almost no paint and dabs of 2-3 colors of green on the brush at the same time. Just make circular motions to form the trees. Add some trunks when done.
