Why drag brakes on a small cut of cars?
I could see it if it was a big yard cut, say 40 cars or so, you drag the brakes on the end up to you…but on a small cut, 10 or so, why risk geting fired dragging flat spots on the wheels?
And skidding wheels dont screech much…all the ones I have heard sound like frying bacon, a sizzling sound.(seriously)
Murphy, dragging locked up wheels makes flat spots, along with building up spall, or melted metal built up on the edge of the flat spot, part of the thumping sound you sometimes hear coming from a trains wheels.
Bigger than two inches, or two or more within two inches of each other makes the wheel set condemnable…and if the trainmaster is in a bad mood, gets you fired.
So you try not to drag a locked up brake if you can.
Yes, most class 1s have mobile repair units that go out and do some of the minor repairs, brakes, small stuff like that.
All of them have a big moblie repair truck(s).
Major repairs, if the car is movable, are best done at yard shops; most yards have a RIP facility for light duty repair and a car shop, to do the big stuff.
Say you corner a car, or find one that has been whacked pretty good…the car body isn’t leaking, but the side or end ladder is pretty busted up…or the brakes have lost a shoe or two.
As long as the car can move safely, you stick it on the end of the train and take it with you to the next yard, or assigned RIP track and drop it there.
What if you find a burned out bearing…you do what it sounds like these guy did…limp it off the main to the nearest siding, and leave it for the mechanical department…who will come out and fix it there.
