I mentioned a very easy and effective way to do that in my first post:
The errant bits of ballast will bounce into the area between the ties, unless you’ve already over-filled those places.
For ballasting,I used a foam brush behind the dispenser as I went along the track. Used a brush as wide as the ballast so that it is removed from the ties outside and inside the rails. After a little practice(repeated short strokes with light pressure)it works pretty well.
FYI
All Electronics happens to have mini vibrating motors in stock:
http://www.allelectronics.com/item/dcm-371/mini-motor-vibrator/1.html
Have Fun!
Ed
I use the container the ballast came in to pour on the track. Then use paint brushes to smoothout the ballast. Lastly, I use a tack hammer to lightly tap on the rails to settle the ballast. Then glue.
