Since I’m lacking power I’m thinking of wallet-healthy way’s to get more juice to the tracks. I have a giant 24 volts 12 amps transformer. (About the ZW size), but unregulated. The thing in my mind is to make a lever which slides across multiple contacts, wired with 0.5 Ohm resistors. Every contact down will add 0,5 ohms. In theory a 0.5 ohm resistor under a load of 4 amps (max power for a railsection) will drop the voltage by 2 volts. The wattage I’m planning to use for this is 10 watts for every resistor. (2 volts x 4 amps = 8 watts).
If using 10 resistors to step down the voltage it will result in 100 watts of powerconsumption for a short time.
I know that if you put 2 resistors of 0.5Ohms in series it will result in 1 Ohm, and according to that the voltage drop at 4 amps should be 4 volts. BUT can anyone tell me if I’m right with the wattage of the resistors? I mean, am I right assuming that the load on the resistors will be divided equal (2x 8watts) or does it cause that one fries and the other handles the stress with two fingers in it’s nose?
If I’m correct, I can make a double regulator with 17watt resistors, which is the heaviest in cheap resistors.
Plan: O-{R}-O-{R}-O-etc. The O’s are the contactpoints, the R’s the resistors.
That directs me to my second problem.
I want to have a short cirquit safety build in. I was thinking of a lightbulb in series with the regulator. But which voltage and which wattage should I take?
May be someone else has any bright ideas?
