Basic Function Assignments
What are the basic function assignments (ie. F0 = Headlight, F1 = Bell…) for the Intermountain Gevo series locomotives? I am also needing that same information for a nonsound Athearn Genesis SD70ACE. Thanks for any help guys!
The decoder in the Genesis is a basic, non-sound TSC decoder.
Basic NMRA DCC Function Assignments don’t go beyond F1 because at the time they were created, sound and all the light functions available in today’s decoders were not even thought possible, so it was left up to the individual decoder manufacturers to determine which functions they would implement.
Intermountain Gevo with Loksound …
F0 Directional Headlights
F1 Bell
F2 Playable Airhorn
F3 Coupler Clank
F4 Dynamic Brake
F5 AUX3 (Set for Numberboards)
F6 Forward:AUX1 + AUX2 (Ditch Lights Front-Flashing) Reverse: AUX4 (Ditch Lights Rear non-Flashing)
F7 Dimmer
F8 Sound (On/Off)
F9 Diesel Manual Notching (Up)
F10 Diesel Manual Notching (Down)
F11 Compressor
F12 Air Dryer
F13 Switching Mode
F14 Sanding Valve
F15 Short Air Let Off
F16 Radiator Fan
F17 Brake Set / Brake Release
F18 Spitter Valve
Mark.
The Athearn Genesis SD70ACE either comes with a Soundtraxx Tsunami decoder or DCC Ready with both an 8 and 9 pin plug. They don’t come from the factory with a non-sound decoder.
Mark.
