I have a N scale layout which I’ve used a 2" foam for the base. Mountains, and banks will be carved out of foam or using plaster cloth, but in the general flatter areas what could I use as a ground cover so it doesn’t look so “perfect” and a little more natural instead of just painting the foam?
Check out the Woodland Scenics website, along with a search of other manufacturers, and look for YouTube videos on how it can be done.
Woodland Scenics might have videos on their site.
Mike.
I plaster cloth it, sometimes with litle mounds of foam under and then zip terxture it.
Scultptamold sticks well to foam, can be tinted and painted with craft paints and is lightweight. It can look like it has fibers, so go over it wearing wet latex or non latex gloves.
This is my first experimental rock casting with sculptamold, not that you want or have to cast rocks with it.
There are a lot of different ways to get the look you want and lots of great You-Tube videos. This is just one spot on the layout. I found some tea towels in the kitchen drawer and dipped them in Plaster Of Paris and had them covering those cardboard strips before the wife knew they were gone.
I don’t cover the foam with anything, just carve and paint.
Paint the foam brown/tan. Go outside get some dirt,its free. Scrape off the top its dryer.
Dump the dirt on foam, mess with it till you like it. Mist, then wet with alco./water
glue with white glue/water mix. Add some green stuff/trees
In N scale you wouldn’t need much to hide that flat look
I use very finely sifted dirt as well. I just paint the foam with white glue and sprinkle away. For most areas this is good enough, however, where a critical eye or camera may snoop, I will use left over tile grout or thinset and airbrush it to the colour I want. No matter how finely I sift real dirt it is just too big for photos. Grout and thinset are like powder and you can even throw in some weathering powder to the mix.
For sifting real dirt, use some old nylon stocking material . When I sift with this, the dirt is has fine has flour. You have to sift it over some wet paint or glue- vacuum off excess.
I guess a lot depends on where you live. Out here on the rocky West Coast, fine dirt is small rocks.[(-D]
Big flat expanses look unnatural to me, so I usually start by gluing down scraps of foam, then using plaster cloth to get a smooth contour. Next I skim coat with Gypsolite, a rough, grainy plaster. I paint the Gypsolite with a camouflage pattern of green and tan. If I am putting in rock pieces, this is the time.
The next step is either glued down fine turf and other scenic material, or static grass.
Obviously, I’m not in a hurry.
Get yourself some great scenery books. They give you a lot of helpful tips, tools, and techniques that make the effort more realistic.
Regardless of the method(s) you use, consider going for variety. Mother Nature’s hardly uniform. Pick different textures, colors, etc. to make things different. You can take some spare foam you use for making depressions and make them mounds or hills.
Had I done that, it would have resulted in me being dipped in concrete, and getting a one-way boat ride on very-nearby Lake Ontario.
I was doing some scenery work last night…well, early this morning, and wrapped it up just a little after 4:00AM. Most of it was ballasting track that was laid directly on plywood, but also on the supply/service track of Mount Forest’s coaling tower, which is on a styrofoam incline.
I was intending to add some photos of that session, about 14 square feet of real rock ballast, real dirt (really, really fine, too), ground foam of various sizes and colours, and static grass, also of various sizes and colours, but they will have to wait until photobucket gets their you-know-what together.
I used garden soil from my garden, sifted through nylons/panty-hose. It seemed reasonable to do, and I got it sifted and rolled nicely. It was when I went to wet it that it changed texture and ended up drying rather too coarsely…IMO. Looked good, not great…in photos, close-up.
Note that I added some Plaster of Paris powder to the mix before I place it, and then I rolled it with a small baby food glass jar. Then, I spritzed it with the same light glue/water/detergent fixative I use for scenery cement, ballast glue, and for overspraying scenery if I want it to be extra-firmly adhered. Meant I had to wipe the tracks very thoroughly immediately. Had to be very careful because this was in the yard with tons of tracks, lots of turnouts, etc.
Small rocks are NOT dirt!
Most of my layout is on wooden benchwork, with the track either on cork roadbed, or directly on the plywood. I am starting to use extruded styrofoam for some scenic forms, but the only place I’ve used it to support track is for the ramp up to the dump-pit for coal and sand at the Mount Forest locomotive servicing tracks…(any of the tiny images from photobucket can be clicked-upon for a larger view)
This is part of the area that I worked on last night, as mentioned previously, and here are some photos showing the results…
Can’t wait to see the results. They were probably better at 4am than me working at 4pm! I too work late, but nowhere near graveyard shift.
No need to wait…they’re in the post above yours. Simply click on any of the puny images for a larger view - I think that they may have elves running photobucket.
I cover everything with Woodland Scenics T-49 blended green ground foam.
Then I add layers of everything to make the scene come alive. A little “Flock And Turf” from scenic express, other WS products, small stones, twigs, ground up tree bark, whatever. I usually do not securely glue anything down above the base of T-49 so I can vacuum and refresh the scenes as I want to.
-Kevin
There’s a reason they are called the Rocky Mountains. Get out of the trees and the “mountains” are nothing but piles of rocks - usually big ones!
I also use 2" foam for most of my layout. Tho, I model in HO think this will work in any scale.
In the fall when the leaves fall, while they are dry, I rake them up and put them in a large trash bag. Take them to the garage and run them through a blender. Run the results in a dollar store cooking strainer. Any thing that will go through the strainer works great for city ground cover, what won’t go through the stainer is country ground cover. Especially wooded areas.
Mix it with white glue and apply direct to foam, or any other surface. Lots of glue and you can apply it with a brush, drier you can will need to apply it with a puddy knife.
Add the green ground foam later. If you run out of the fine or medium foam and only have clumps left, run the clumps through the blender too.
Had watched an Allen Keller video where I learned about using the leaves, but the video soaked the leaves in water to run through the blender then dried them in the kitchen oven. I didn’t think my wife would approve of using the oven so since in Colorado the leaves stay fairly dry I skipped the water part. She won’t allow the blender to be used with food either!
If your worried about mold forming as this is an organic product, you can always add some Lysol, alcohol or Clorox to the white glue. Once dry the leaves parts are encased in the glue and pretty much protected from humidity or wet surfaces. I’ve not tried it, but you might also add fabric dye to color the leaves in the application process.
[quote user=“Webnerdnick”]
