Bath & Hammondsport RR Enginehouse Plans/Total Access
1.) The pdf file is a read only file, can not be edit.
2.) Yes the file can be printed but not at 252.6 percent, either 252 or 253 percent. Not a big issue.
3.) One need a password to bring up the document in an apps other than the Adobe Reader.
4.) It states on the document the following:
This material may not be reproduced in any form without permission from the publisher.
www.modelrailroader.com
Neil I hope you read this posting because I do not believe you can call this document Total Access.
Thanks for letting me blow off a little steam
Joe
At the very bottom of the page is a field of blue with links. At the bottom of the far left column is a “contact us” button. You MIGHT get more satisfaction there by contacting them.
Naturally, MR is going to want to copywrite anything they publish for their protection. That is the nature of the printing/magazine/book business.
Good luck
[8-|]
It appears to me that the on-line plan is the same as the one in the magazine. Why not just copy the magazine plan in whatever format you want and enlarge/edit as much as you want?
Galaxy:
Thanks for the info, I will give it a try.
Maxman:
I know the doc can be copied, bet the point is Total Access.
Joe
