Battery power
If I go to battery power, how many locos can be driven together, I ve got 5 dash niners, and an SD-45. Want to lash em up all together, what kind of power consumption does this demand from the battery, or should I say , maybe batteries. Looking into this aspect of power in the near future, dragging about 30 box cars. Keep seeing those posts on battery driven railroads, just a looking!!! And lastly, how do you go about charging and recharging without buying a seperate battery charger, Can they charge by running electric D.C.
MM,
Maybe Marty Cozad will read this thread and give you concrete answers. In the meantime, I’d guess you’d be running a battery car for each loco. Some of these large 2-motor diesels draw upwards of 10 amps at full load, that’s a huge load on an on-board battery pack.
Walt
Char
Keep an eye out for the mail man,person. You’ll have the answer. It depends on what RC unit you use and how its needed See my winter photos . the 30 car coal train with 3 -9 pulling. I have made some dumby units cause 3 units will pull most RRs apart, so it will save battery if you run two units. I rewired all my USAT the same way that Aristo comes from the factory. I wich they all would learn from Aristo…
I have an RCS unit that is 10 amp and its working great in a trailing car. I also have 6 TE units. Takes time but I let others run the trains when they visit. Or they bring their own trains.
Later
