I connected the BD4N to the Command/Booster Module as instructed in the manual page that comes with the BD4N. According to that the RailA is common and it looks like the detection sections are on the RailB side of things. So I connected the detection section terminals to the isolated RailB sections. All sections show detection!! Even if there is NO loco!!
If I assumed I was wrong and connected the detection sections to isolated RailA and treat the RailB as common, there is no power given to the track. Very frustrating!
What device is the BD4N reporting to? That is, what is at the other end of the OCC Out 10-pin flat ribbon cable? Are the connectors on both ends of that ribbon cable connected/aligned properly?
My setup has the BD4 OCC Out signal connected via 10-pin flat ribbon to the nearest SE8C board, which takes the info and sends it through the 6-conductor LocoNet cable to the Command Station and through the PR3 to the laptop PC on the dispatcher’s desk.
Okay, it’s been a month and the OP has not responded. No big deal. But if he’s still around and reads this, here’s something he can try . . .
Remove all engines and lighted cars from the detection sections.
Connect the wires as described in the first pararaph where all sections show detection and all green LEDs are lit.
There is a trim pot on the lower right corner of the BD4N. Turn the little knob all the way to the left (counter-clockwise). All green LEDs should go out.
Bring the engines and/or lighted cars into each section one a a time, and the green LEDs should light up one a a time.
Bring the engines and lighted cars out of each section one at a time, and the lights should go off one at a time.
If the green LEDs don’t light up as each car comes into each section, turn the trim pot knob a tiny little bit to the right (clockwise) until the lights light up. Then remove the cars to see if the lights go out. Fiddle with the trim pot knob until consistent results result.
I hope this works. This is pretty much the end of my knowledge and advice. Good luck.
