Hello All! My name is Diego Murray, I’m from Brazil and live in Rio De Janeiro city. The forum is great, many information about the railroad model. I hope help and learn in this railroad forum.
I’m starting the construction of a railroad with my father and we have some doubts of how to make vegetation without kits purchased in stores! If the friends have any idea would be grateful!!!
Ground cover can be green or brown latex house paint. While the paint is wet, sprinkle sawdust, dyed green, into it. Roadside weeds can make decent trees. Or, twist a number of soft wires together to form the treetrunk. Un twist some to the wires to form branches. Coat the wire armature with stickum and then dip it into the same green dyed sawdust to make leaves.
I was planning to make a dense vegetation, as many trees very closer together. For it I was planning to use polyurethane foam applied in tufts not uniform and then dying with a ink, it would be a good technical?
Another method is to buy polyester pillow stuffing, it looks like a huge cotton ball. Pull it out to thin it and spray paint it with green or black paint. While the paint is still wet sprinkle ground foam or dyed sawdust on the fibers. Shake of the excess and give it another hit of paint or hairspray to lock the foam or sawdust in place. One bag of it can make dozens of square feet of “trees”.
You can then find weds that resemble tree shapes and dry them. Once they’re dry, cover them in the ground foam and you’ll have a good looking forest in no time!
To reduce the amount of paint needed to color the ground up foam, I would suggest that you visit a florist and ask about purchasing the green foam that they use to support flower displays. I use an old coffee bean grinder to grind up the green foam clumps. I use twisted bus wire to form the trunk and branches of close-up tree. Background trees can be formed cheaply from furnace filter circle pressed onto thin stained BBQ skewers, or just use stained toothpicks. While a bag of Woodland Scenic Foliage Clumps is quite expensive, I mix the ground up clumps with green colored ground up foam, or fine sawdust. Distant trees are slightly bluish in color and can be made without trunks, by forming clumps of furnace filter wire, spray painting it with spray adhesive, and then dipping in piles of varied colored ground up foam. Then, glue the clumps to a stained background. This is the way to create dense foliage, over large hillside areas. Bob Hahn
MR magazine had a short article not too long ago where they used dyed cotton balls in different shades of green to simulate dense foliage. Outline your area with small nails so your forest won’t “roll down the hill”.
If you are planning on modeling vegetation so dense that the crowns of your trees blend together in a solid carpet then you don’t want to expend the time or the effort - or the monies - to model trees where the trunk is not going to be visible to the viewer. One technique for this is to place individual trees in the foreground and suspend a netting stretching back to the backdrop and cover this netting with material simulating the crowns of trees.
