Beginner Scenery - Afraid of Mistakes Normal?
OK, as you may know from my previous posts, I’m working on my first section of my first layout and I have track down on cork roadbed and the trains will run on the track, so small victory. Now, I’m getting ready to start scenery, in particular laying ground cover and ballasting the track. I have this fear that it will end up looking awful or that it will be harder than you all make it sound. :slight_smile:
For those who remember their first layout, how big of a learning curve did you run into when you tried to take your layout from track, cork, and plywood to something more? I guess my biggest fear is that it seems like it will be very hard to undo anything that ends up looking lousy. Since it’s all glued down, etc. Or maybe I’m just being paranoid. :slight_smile:
Thanks for listening,
Mike
Mike, “welcome to the club”!
My first real layout was a sizeable Lionel in the mid '50s, and the current one (under construction) is a two level HO - with several between them.
Putting in scenery has always been kind of hit and miss for me. Taking that first step is often hard because I didn’t want to screw it up. But the thing is, most all the time it worked out well. And the few times it didn’t, as soon as I fully realized I wouldn’t be happy with it - boom, out it went!
Even with the layout I’m building today, there is still some procrastination and tentitivity (spell?) to start new areas of scenery. I - like you I am sure - want to do it right the first time.
My point is, jump into it, don’t rush, and don’t try to do too much at a time. It will work out fine - or in any case - give you valuable experience. By the way, leave the ballast for last!
Building a nice layout requires a lot of different talents, which are not always evenly distributed. A friend of mine is an expert when it comes to wiring, but shuns away from making scenery. I have a fairly good hand at scenicking my layout, but hate wiring. Whenever I grab a soldering iron, I end up with a lot of burns [:O]
As scenery is the most obvious “aspect” of our layouts, any mistake is readily visible, but that should not stop you from tackling the issue. Mistakes can easily be corrected, and each time you learn a little more on how to improve it.
If you are afraid to “foul up” your layout, why don´t you hone your skills on a little diorama - the best way of trying different techniques.
Don’t worry about it, but learn from your mistakes as you go. Have been in HO since 1959, have made my share of dumb scenery mistakes, but it is much easier (in my opinion) to tear it out and do it over (better) than rewiring a layout.
Just remember with scenery, most of nature is pretty plain, don’t try to do Mt. Rushmore and the Grand Canyon, instead keep it simple and believeable. Scenery, once you have a solid base, can be improved on much easier than most tasks in the hobby.
Bob
Sorry, but your diagnosis is “PERFECTLY NORMAL.” If you don’t feel confident, you can either do a diorama, as mentioned above or just start at a place on the layout away from tracks and other elements that could be adversly effected. Give it a try and see how it goes. As was said, we all have our nitch, some build better trees others are a whiz at rocks others buildings, most seem to find ballasting a drag. I’m not quite ready to start that phase yet, so I still have that to determin.
Even many experienced, talanted modelers tear out sections of their layouts to improve them, though many of would give an arm and a leg to have our layouts look that good. Making changes and improvements is a normal part of the process. A layout is never done is often mentioned.
What I plan to do is get the basic track layout down, so I can run trains. Then I will start the scenery at some given point. I haven’t decided yet whether I will just keep adding to that first area or go to another area to do some different type of scenery. The second option would give me a chance to try different things more frequently, but I wouldn’t have continuous scenery. I do expect that before I am done with the basic scenery, my skills will have improved so that I will be ready to go back and improve the area(s) where I started.
I’d say grab some scenic materials, glue and go for it. Just make sure you protect your track and TURNOUTS so that you do not have to do a major reclaim job on them.
Have fun,
One thing just jumps to my mind - we hardly plan the scenery when preparing the track plan. One of the most common mistakes is to put too much track on the layout and to squeeze the Grand Canon in between.
I always prepare my track plans with the scenery I want to have in mind.
If you don’t like how something came out it’s no big deal. Just tear it out and try again.
… unless, of course, you are a brain surgeon.
Yup, fear is normal. Call it “apprehension” if that sounds better.
I started in a corner of my layout. I was pretty happy with it. Over the next 3 or 4 years, I worked all the way over to the other edge of my layout. I could see the work improving with practice, sort of like looking at the fossil record by digging down into the earth.
One nice thing about scenery is that plaster cloth, turf, ground foam and paint are all pretty cheap. If you don’t like it, rip it out and try again. We’ve all done that, and by the second or third try we usually get it right.
If you make a mistake, take a look at the real world, nothing is picture perfect and odds are no one will notice the mistake. Or just let it go and come back in a day or two and wonder what you were worried about. For example I made a mountain and tunnel and when I went to paint and ground cover it I thought I ruined it but I pressed on knowing that if it still looks bad I can redo it, after all it was just plaster and paper. When I was done I was still upset about the out come but I left and went to bed… the next day, it looked fine, all the little things I felt I screwed up on the night before I did not see when i went back the next day as i was looking at the big picture now.
Like said don’t worry, mistakes can be made and easily corrected. I have made bad mistakes and good mistakes. The bad a tear out and redo or just hide really well. The good mistakes are when I do something unintentionally that actually turns out well. I have learned many techniques accidentally.
Getting a book by Dave Frary is a good start to helping you along but don’t be afraid to try your own ideas. That’s what this hobby is all about. Somethings turn out good, others bad.
One key thing is don’t make things to uniform or matching, as that isn’t reality. One thing I notice where this is most evident is grass. I mix and match my static and foam grasses and never lay the same color patterns anywhere. I make things close but never exact. It adds to the realism as most grassy areas in the real world vary quite a bit. Even neighbors yard grass can look drastically different.
I also use a mix of trees. Some are bought premade, some are super trees, some super sage, some made from scratch, some just whatever. I also don’t subscribe to perfect trees, after all they don’t exist. I have some super trees I broke when installing them so they are lopsided, however it looks perfect for a tree that was struck by lightning.
Most important part is to have fun and enjoy what you are doing. If a certain task becomes to daunting leave it alone and come back to it later.
I agree with the rest regarding going easy, going small, and not being too critical. Some good things about scenery is that ground foam and bushes or clump foliage cover anything. Adding more ground foam to an area that you didn’t like just adds more texture and maybe more contour. I have some nice rolling hills where it used to be somewhat flat. Clump foliage and bushes you can just pull out and replant.
And a do over doesn’t have to be a complete rip out and toss. Using white glue and other water soluable adhesives means the water spritz bottle is your friend. By resoaking an area, you can have a soft do over.
Using a smaller ballast size (medium or fine or a mix of both) is easier to spread evenly than large sizes.
I have had trains running for several years and add scenery a bit at a time.
Remember rule #1 - Have fun!
Hi Mike:
So your first attempt looks awful, so what? This is a HOBBY, not a competition. Just try again. Everybody’s a beginner at some point. It takes a while to gain confidence, to become familiar with the materials, and what looks good.
My advice to you is to relax, buy a book or two, but above all, to go outside and look around carefully, and carry a camera with you when you do so. What you want to avoid is imitating the work of other modelers. Everybody’s idea of what’s “realistic” varies. Nature and the prototype can’t be argued with. Be guided by them & you can’t go wrong.
I’ve been doing this stuff for over 45 years, and I still find ways to do things better, make it look more “realistic,” etc.
Regards,
-Ed K
Learn as you go, and don’t marry anything you see. Do a small length of ballast and glue it. Spread some ground foam around it without gluing it in place. How does it look? Ballast could be leveled a bit more? Too much of it showing above the ties? Inner rail webbing has too many little pieces of grit stuck up against them? The shoulders of the ballast are too uneven? Every one of these, if you notice them, is something you can do better by trying something else. Learn as you go. At some point, you will have to wet and soften the first 10" of learning, scrape it up, and then re-lay fresh ballast the way you know it should be done. If you meet the challenge of making it seamless with the improved lengths, you will be done.
I like the idea of a diorama. Even one square foot on a piece of junk 1/4" plywood can serve as a great learning surface. Try stacked foam. Try aluminum window screen and strips of casting plaster cloth overlaid. Or mix up a goop, or try spackle. I’m pretty sure you’ll find that they all have their purposes and qualities, and that you are pretty good with any of them with enough patience and practice.
Go slow. Speed comes with competence. Build competence and versatility, but not in a single afternoon.
Crandell
Remember, if you don’t like how your scenery looks, rip it out! It’s not that hard. Most likely, your scenery will look fine at first, and then as your skills progress, you’ll find that you could have done this better or that differently. And then, by all means change those things.
Unlike real geography, which is there for the ages, model scenery is like the Las Vegas Strip. If you suddenly decide that the mesas of the desert Southwest should give way to the soft, rolling hills of New England - BOOM, and you have a slightly dirty slate.
Our society as a whole suffers from a pervasive idea that WE SHOULD NEVER FAIL. Horsefeathers! Nobody’s first effort at ANYTHING was perfect. Most weren’t particularly good. My first scenery efforts were a dismal failure - but they were also a learning tool. I’m still no threat to (insert name of master scenery builder of choice,) but my wife didn’t giggle when she saw my most recent work.
Rather than fearful anticipation, try some study - our hosts sell a plethora of scenery books - followed by a little action. You might find yourself pleasantly surprised. If, more likely, you don’t find your first cut inspiring, clean it off and try something else. Above all, remember that nobody will be grading your work (except the cat in YOUR hat, of course) and initial lack of success won’t flunk you out of Model Railroad U.
Some indefinite time in the future, when you charge into a model of Zion Canyon with the confidence of experience, you’ll look back on the present and wonder what you were apprehensive about.
Chuck (Modeling the cedar-forested mountains of Central Japan in September, 1964)
Whether afraid of making mistakes is “normal” or not, If you do “fail” you can always start over if you don’t like what you did or how it came out.
I am not sure there are any real mistakes, just dislikes of what you have created…most likely because it doesn’t look like a picture in a mag. on the box cover, on someone else’s layout or photos of someone’s layout, or postings here on the forum.
Some guys are more creative and detail oriented than others. some go for representationalism of what they want to portray.
Even “professional” Movie FX guys know what to super detail, what to detail, what to leave out and what to only create as a “representation” of what they want to show for a background of a movie or TV show,as the eye can be fooled or fill in details.
Many of us never “finish” a layout…cuz we are afraid it won’t be “perfect”. I ask: “perfect” to whom?
TO answer your question, of course there is a learning curve on your way in building the scenery for your layout…each time you try a new proceedure you learn something. One of the joys of mags like MRR and this forum is that you can see what others have done, often with step by step instructions so you don’t have to learn “quite so hard” the hard way![8-|]
My father recent got into playing with my and my brother’s old trains. I dug out a box of stuff I had packed up of O guage train stuff. I said “boy what a crappy job I did on some of this” He said" you have to remember what your abilities were at the time, and the materials and tools you had to work with to create what you did." I haven’t forgotten that and apply it to everything I do now. Perhaps that phrase can help you too.[8-|]
Like you, I was very apprehensive about starting scenery on my first layout. But I wanted to look at more than some plywood and Homasote and track. And the track wasn’t even nearly finished.
My first step was to break out the saber saw and cookie cutter the track and roadbed. I left intact the areas where I planned track but hadn’t laid it yet. Vacuumed up the sawdust and Homasote dust and said, “this wasn’t so bad after all”. I now had open space where scenery was to go.
I had read an article in a 1960s Model Railroader about using cut up grocery bag paper and masking tape to install some temporary scenery before committing to plaster. I tried that, and that really helped spur my refinement of the scenic plan for the layout. I have seen others put in kit boxes or cardboard cutouts as stand-ins for structures, and that also helps with refining the scenery ideas before committing. I said, “this wasn’t so bad after all. I’m liking this layout better.”
After monkeying around with the paper bag paper and tape for a few weeks, I bought some window screen. The first batch of screen was aluminum. Use the fiberglass screen instead. The wire is hard on the saw blades and bits when you decide you goofed and want to take it out. I stapled the screen wire to the cookie cutter roadbed and shaped to my heart’s content. I mixed up Plaster of Paris with some food coloring in it to make it brown instead of white, and used paper towels dipped in PoP laid over the screen. I was quite happy with the results, except for one area. I got out the saber saw, cut out the offending section, and put in new screen and plaster to my liking. I said, “this wasn’t so bad after all. In fact, I declare it to be good.”
Just like other most other aspects of model railroading, I found out that scenery isn’t all that hard. It mostly takes a willingness to keep trying until I satisfy myself. Since I
I have to assume that you have an HO layout. Go for DCC from the beginning. Most of us old timers have to convert from DC to DCC. DCC allows you to run several locos independently. Go for radio controlled DCC, (if you can afford it). Strangely, no one mentioned to go to your Local Hobby Shop (LHS) and buy several Kalmbach books on Scenery, Ballasting, etc. Search the Trains.com/Forums threads for help. What is the location, era, and theme of your layout. Many of us choose the 1950s era of transition from steam to diesel. My layout is a freelance, mountainous area of logging, mining. and iron & steel complex. I use plywood reinforced arcs,heavy screen wire covered with plastic cloth and then Sculptmold and Hydrocal plaster. Before spray painting the terrain, I suggest that you drill holes where you intend to “plant trees”. It’s less messy to vacuum up the white powder and then spray paint the various shades of brown and rock colors. For a large canopy of trees on a hillside, I use stained double ended skewers, with 4-5 circles of green painted furnace filters pushed onto the skewers Get several bottles of Woodland Scenic fine and medium foam, of various colors, to sprinkle onto the adhesive sprayed tree frames. For foreground trees, I just purchased the Super Sage starter kit, on which you are given Super trees for gluing onto the sage trunks, to provide a many branched tree frame. The $78 kit contains all the material you need to produce 18-24 perfect scale deciduous trees. An excellent manual accompanies the kit. Bob Hahn
Mike,
I was the same way. I just starred at my layout totally afraid of where to start. So I figured I would practice a little and make a diorama.
I went to Home Depot and purchased a 2’x4’ piece of thin particle board and then glued the same size foam board on top (some sort of foam board I found in the isulation isle). I laid down 3 separate pieces of cork roadbed and then glued 3’ pieces of flex track to that. I went to my LHS and picked out whatever scenery looked appealing and interesting to me. Although I knew I was going to do the southwest desert theme, I wanted to try some trees and foilage stuff too.
Then I began to hone in all the skills needed for the real thing. I soldered some bus wire to the track to make it functional (and is now my test track). Then practiced 3 different techniques of ballasting and colors. You get the picture. All in all this was a great way to practice because there was not the pressure of screwing up the real deal. Good luck with everything, and as you can see, there is a lot of help and support here on the forum.
Shawn.
Mike,
I think it’s normal to be apprehensive when doing something new. I wouldn’t worry about it if I were you. Take the Nike approach and “Just Do It”.
Even with glue, it’s pretty easy to remove something and do it over, or to touch up something and make it better. I have a funny spot on my layout. I made a classic New England cemetery, complete with all kinds of headstones and a stone wall. I wasn’t terribly happy with it, but it’s the first thing visitors comment on: “Wow, cool cemetery! How did you make it?” So i keep telling myself I’m my own worst critic, and it’s actually grown on me over the years.
That said, I did cut my teeth on dioramas. I built one for “Take a Model Train to Work Day” a number of years ago ,and one holiday scene for under the tree. I had a blast making them, and they were real confidence builders – especially the nice comments from my colleagues in the office.
