Benchwork: Why a hollow door?
I had used oriented stand wood. My piece didn’t last long, it wasn’t stable and fell apart by the corners. A few weeks later it was crumbling around the center destroying the layout. I never trusted it ever since.
$60 here gets me a solid door - in fact, I’m building a workbench L shaped, using 2 solid core doors as the tops, and each one is $49.95 at my local Lowes. $60 for a hollow door better come prehung. Yes, they have cheaper plkywood here than $35 a sheet, but it’s the kind of junk I wouldn’t want to work with, maybe OK if putting foam over it and using the
Did you have it supported by anything? You can’t just stick 4 legs on the bottom of a piece of OSB or plywood and have it hold up. You also need to stay in from the corners with OSB, there’s not much pullout strength for fasteners at the edge.
It was supported by different objects. What ever was free to sit on. We never had enough money for legs, scenery and structures.
I went with 1x4s and 1x3s assembled into rectangles bolted together with bolted on legs and 3/8" A/C plywood screwed to the top with drywall screws. On top of that I glued sheets of 2" Blue foam to build up the scenery. This allows for portablility of the benchwork. Also you can probably walk on it if you need to, and I can mount a turnout motor, signal drivers, circuit boards, LCC nodes any any manner of other digital equipment under the layout because of the plywood layer. Worth the few extra cents per square foot if you ask me. I would not touch OSB with a 39.5 foot pole.
Also if weight or size of plywood is concern, Home Depot (and probably Lowe’s will cut it for you for free (up to 4 cuts in my area, 50 cents or so per cut after 4).
Y’all are missing the point: most big box stores have damaged hollow core doors; one side has been damaged in shipping and they can’t be sold. Usually they will sell it to you for about $5.00; at least that’s how I got my four.
Which is great if you are making a rectangle. If you need to change the size/shape then you have to go and make structural changes to the door, and while it will still be cheaper, you will end up spending time better used building other kinds of benchwork. If you have the $$ spring for better benchwork.
I scrounged 17 HCDs of various widths from neighbors doing home remodeling projects. The only cost was my pride as I scavenged their garbage curbside. Maybe nobody saw me.
The lengths do vary slightly, a couple had damaged faces and the room entry ones have holes for doorknobs cut in them, but since I put foam over them, it really didn’t matter.
