I’m building on the latest articles about G “scale” (more or less, looks like I’ll be doing 1:24 which really isn’t scale anything) indoors. I have a 50’ basement space, but would prefer not to put much on the floor. Preliminary experiments indicate that I may be able to suspend from the ceiling, with occasional wall brackets to minimize sway.
Clearly, there are some significant issues with long spans between supports, but I’m experimenting with 1/2" plywood as the base, with 1"x1" steel angle iron underneath. I’m bolting the two together every 2’ or so, so it will be pretty rugged when done. I now have a 16’ piece that looks like it will be sufficiently stable even if only supported in two places - thus roughly 8’ spans.
More data will be supplied as I learn it. Clearly, for this type of installation, the modern light weight construction is necessary (foam for scenery rather than plaster on some even heavier support.
The next interesting experiment will be the necessary ceiling brackets.
