i made good progress today . benchwork framing is done. so the railroad has its place and its size is defined . plan is to get foam tomorrow . plus sand caulk prime and paint framework. i was going to install wire looms but i will wait as i dont know where to place them yet.
i like order but you surely cant tell that by looking inside my shop right now
layout will be a little tall for most folks i guess at 44.5 inches before foam but works great for me standing or sitting. benchwork is raised 4 inches above the salvaged gift card shop drawers that supports the also salvaged 2x4 framework. bracing is at 24 oc
it ended up smaller than i had planned at only 4x8 but thats still a lot of N scale space. it has adequate space all around it also . i was going to build it
4x9.5 but could not justify the extra expense of another sheet of foam right now. or the extra labor to splice .its square within a 16th . level all the way arond . and very tight . i used #10 x 3.5 hex head woodscrews .
i really did not want to use the 2x4 but i was short on 1x4 material. so total cost on it was the 4 bucks for the screws. the lumber is not pretty but its
structural and will be fine after the air sander finished with it.
im real happy with it as i had my doubts though as this is the first thing i have tried to build since my sight loss. progress feels real real good[tup]
