In deciding on what to do about benchwork, I can across the following site:
http://www.sieversbenchwork.com/Index.html
Looks very promissing and pretty resonably priced. As I’m not much in the carpentry department (I can do it, it just won’t be pretty ) This looks to be relativily easy to put together, expand, and layout in various arrangements.
Now mind you, this may seem like it might be more than just rushing out to the hardware store and buying all the materials, but factor in the cost of the table saw, the drill and bits and various other tools you’d need to build it and it seems to come in better.
This seem to also be a good item for those that are in a place with limited space and can’t have the power equipment around. It also seems to break down easy for transportation, if you need to move it about.
So I was wondering, has anyone used it, and if so how do you like it compared to standard construction benchworks.
