I’m ready to form Code 83 guard rails for a bridge and want to assure I use the right adhesive. They’ll be roughly 12" long, allowing for overhang beyond the bridge at both ends.
I’m concerned that CA will (1) cure before I can attach the guard rails properly and/or (2) create a brittle bond between the rail and the plastic ties (Code 100 flextrack for the main).
I have Elmer’s Sitx-All and have seen references to Pliobond in this forum.
Joe, you beat me to it. I wanted to suggest 5 minute 2-part epoxy as well.
Also, there are various grades of CA adhesive, some provide longer working time than others.
Whatever you use, you are going to need clamps to hold the guard rails until the adhesive has had time to set. So, do one end of the guard rails, clamp the end and then move to finish the other end.
Fortunately a guard rail should not undergo the types of pressures and stresses that an active load bearing rail would. I have used ACC (gap filling kind) with success but my bridge was fairly short.
In an extreme case where the length of rail makes you fear for a poor contact area, it should be possible to drill into the base of the rail and solder a short length of rod or nail or pin that would in turn slip into a hole drilled in a plastic tie. Even that bit of an anchor could make the rest of the cementing hold much more reliably.
In the alternative it could also be possible to file away a bit of the metal base of the rail and replace it with a piece of styrene that could be epoxied into place, then filed to match the profile of the rail, so that a solvent based cement would hold the guard rail to a couple of plastic ties.
I am not aware of anyone who has ever made the product, but a case could be made for a styrene casting for a length of guard rail.
I used CA on mine. I had no trouble getting them positioned correctly, and they’ve been in place for years with no issues. Make sure the ties and the bottom of the guard rails are paint-free and clean before gluing them.
You could try the “poly zap” product sold by Microscale. It looks and works like CA, but is intended to remain flexible to work with slippery engineering plastics, plus it has a much longer working time than most CA. It doesn’t get brittle. I’ve used it to attach rails for a Central Valley turnout kit.
Note that you don’t have to get all of the glue onto the rail before adding it to the ties. You can place the rail, and add CA or equivalent separately. Put some CA or poly zap on a scrap of styrene or wood, and use a piece of wire to pick up a drop of glue and let it flow under the rail one tie at a time.
Another option is Walthers Goo. I have a steel trestle with guard rails attached with Goo onto Micro Engineering plastic ties. It also remains flexible.
Eh? Well it depends, on a bridge, I guess you are stuck with glue. Subways have lots of guard rails, the LION solders his in place. Well, first of all the LION is far to cheap to buy real rail, so him uses 1/6th" welding rods. Yes, they are round, but once in place you can sand the tops down with a Dremel tool and once you have slobbered black paint on them, nobody will notice anyway.
OK, the LION puts a small brass nail every so many inches, and lays a bead of solder on them. Him then comes around with the welding rod, and solders it to these nail heads. Sand and Paint it and it passes inspection, at least as far as a LION needs to concern himself. Nit-Pickers have been eaten in the past, a practice that may continue well into the future.
Had no problem w/ using CA to attach the guard rails on the ME viaduct. I actually thought of using the Pliobond that was used to secure the ME bridge flex track, but thought it may be too messy. The rail was fitted/ shaped and dry fit. The thin CA “wicked” into the contact areas w/o problem. Just held rail in place and worked my way along the length of the bridge. This has held under extreme running at a club setting for close to 8 years now. The ME ties as well as the CV tie strips do have the added advantage of the molded area for the guard rail position. If you hold the rail against the molded spike/ plate detail you should be fine on other track. Just check the guage before permanantly securing. A piece of stripwood or styrene may be needed to set the spacing.
If your prototype has the rail ends bent inward, don’t allow them to touch or add a styrene insulator to prevent any shorts.
Here is a adhesive chart I printed off to keep at my bench for easy reference. Not as complete as it might be, but answers my questions most of the time.
I use gelled contact cement to hold guard rails in place. It holds even when the bridge is removed for cleaning, despite the vertical flexing which occurs under such circumstances.
I built a Cornerstone truss bridge back in 1993, and put in guard rails. They were attached with ACC (metal rail to plastic base) and held perfectly for 14 years. Ha, no one was more surprised and happy about that than me!
There’s that word “best” again. Doesn’t go very will with our hobby.
If you’ve read the previous posts, you’ll see that there are lots of options. all of which work for the person who posted it.
My personal recommendation would be to use a slower setting CA.
Over many years, I have discovered that relying on the adhesive to hold parts of your model in position is a dicey proposition. I have acquired a bunch of specialty clamps, mostly from Micromark, and I use these to hold things in place while the adhesive cures.
Rick, #2 use to be spit! But because so much of it was contaminated by Beer, it didn’t work that well so they removed it.[B][(-D]
Actually that was a good observation that #2 was missing. I hadn’t noticed that myself and I have no idea why it is.
Brent[C):-)]
I decided to use Elmer’s Stix-All, as it has a long working time, is strong, and remains flexible. I’m pleased with how it turned out. Thanks for all your input.
