Best HO scale RS-2 on the market today?
How well does Athearn do in this line? Or anybody elses RS-2 for that matter. Thanks!
Athearn does not make an RS2 - they have an RS3. Kato has done a RS2 in HO, and P1K currently has a HO RS2 available. Atlas also has a RS3 available. I have the RSC2 versions from both Kato and P1K - the Kato is heavier and will pull more.
Jim
If you’re modelling a specific road you may want check if their RS-2s were roller or friction bearing equipped. I think the P1K models are all roller bearing trucks, while the Katos are road specific.
The Katos, though out of production for some time, pop up on e-bay from time to time and are excellent models.
Good Luck,
62stratfan
Thanks guys.
I have three Kato RS-2’s that I scapped up on e-bay. They pop up from time to time and can be quite reasonable (2 I only paid $40 each). They run and look great and I am in the process of upgrading all 3 to Loksound decoders. Decoder install is not that bad becuase they have NMRA DCC plug and with just a little milling of the front weight, I’m having success. Non-sound decoder installtion would be a snap.
I don’t know about the Proto 1K RS-2’s, have never seen one. I just love those great Kato drives that just hum along…
Good luck!
Please, will you publish your experience if you will put DCC&sound to the KATO RS-2?, and specially the way you do. Thanhs.
