I was trying to make some grab irons for a B-unit engine the other day and had difficulty finding a suitable wire for them. I tried brass (0.015) and it tended to break as you put a 90 degree bend on it. I also tried 0.020 spring wire, but found it difficult to cut, bend and trim.
I typically use .012" brass in HO. Occasionally you’ll get a piece, or even a package, that tends to break when you want it to bend. It still seems to be a good material overall, and most of it I’ve used bends just fine.
Spring steel wire can work also, but .020" is quite large for HO at least. It might be worth a try in smaller sizes, but as you’ve already observed it can be unpleasant to work with.
Every so often there will be someone tempted to recommend a softer material like floral wire. Grabs made with it don’t stand up to normal handling without deforming, so it’s to be avoided.
I use .20 and/or .25 steel wire from K&S. I use a flat bladed hobby plier or a very small serrated hobby plier for 90 degree bends. Either one is durable, if not exactly to scale. As there is little visual distinction with either, using the three foot rule ( what it looks like from that distance), it works or me where handling is an issue. I primer it after CA gluing it into its holes in a car body, then airbrush or spray paint with the model color or hand brush as a contrast color, where required. For holes, a .6 mm hss hobby drill bit is used for .20 and a .8mm bit for .25 wire. I try to glue from the inside of a shell where possible. Note that you really can’t solder steel wire, but CA is a decent connecting method where two wires will not be subject to excessive handling. Painting over it makes the joint smoother and hides the glue aspect. I generally use a flat file (metal) on the end of a wire where gluing to a straight piece, to eliminate the " cut " from the wire nippers. Also, use standard type wire cutters on steel wire, not the little wire nippers. Cedarwoodron
I have noticed in the last few Micro Mark flyers that they have a bending tool for various sizes of Grabs.
It looks very interesting and think at some point I will get it. Right now I am too busy with other aspects of the layout and it is in the $36.00 range.
If anyone has this tool and is using it, could you please give us a short tutorial on it and your opinion on it’s benefits, this would be appreciated.
I have used a variety of materials for grab irons, including .015" piano wire for the vertical grabs/handrails on this diesel. The drop-style grabs on the side of the nose are, if I recall correctly, pre-formed phosphor-bronze ones from Tichy:
This carbon black covered hopper from Rail Shop uses Detail Associates .012" stainless steel wire for all of the straight grabirons and , while the drop-style grabs on the car’s ends were formed from DA .012" brass wire:
The curved grabirons on this tender’s ladder are DA .012" brass wire. Due to the curves, the ladder had to be soldered together while in-place on the plastic tender:
The rear ladder was soldered together on a jig. The stiles were formed from DA .010"x.030" flat brass bar:
All of the grabirons on this Red Caboose X-29 boxcar were formed from DA .012" soft brass wire. This material allows drop grabs to be easily formed in a simple plastic jig, especially useful if your prototype used non-standard grab iron widths:
I use thin brass wire, .012-.015". You can make your own grabiron jig very easily.
Method one:
Take a piece of plastic or brass. Along one side draw lines to your grabiron widths parallel with the edge. Mark a line perperndiculer to the edge from the edge across the line. At the intersection of the two lines drill a hole slightly larger in diameter.
Stick one end of the brass wire in the hole, bend the wire over towards the edge, line it up with the perpendicular line. Bend the free end over the edge of the jig. Slide the wire up out of the jig and trim the legs.
Method two:
Get a pair of needle nose pliers with tapered jaws that are at least as wide as the grab irons you want to make. Paint the sides of the jaws a light color. measure the width of the jaws and mark with a fine point marker (Sharpie) the location where the jaws are the width of the grab iron.
Put a piece of wire in the pliers at the spot you marked, clamp witht he pliers and bend the ends over the sides of the pliers jaws. Remove the wire and trim the legs.
I like to use flush cutting pliers to cut the wire (available from Xuron and Radio Shack).
If the brass wire you are trying to use is too brittle, you can always try to anneal (soften) it by heating it very hot with a torch then letting it cool SLOWLY. Do this two or three times and the wire should bend without breaking.
Nice clean work, as usual, from Wayne. Note that phosphor bronze wire that he used for some applications is available from Tichy and is in stock at Walthers
Someone asked about the grab iron bending jig that MicroMark sells. it is a version of an old hint, or “kink,” as MR used to call them, before that word took on a more disturbing overtone I suppose*, and I recall one guy who took a needle nose pliers and milled in a seried of deeper grooves at various places on the pliers so that grabs of varying widths could be made quite easily.
The Walthers catalog shows similar jigs from San Juan Car Company and American Model Builders.
Dave Nelson
MR had a monthly column called “Kinks.” By the time they compiled many decades worth into a book, they titled it 764 Helpful Hints. Good thing too as my folks would have been unlikely to get me a copy of “764 Kinks” for Christmas.
Dave, in my opinion, the best resources for proto-specific details are photos, drawings, or actual on-site observation of the prototype. I’ve also used magazine and on-line articles in which the author has utilised similar resources. Even if one is creating a totally free-lanced layout, emulating prototypical practices will enhance its realism.
Regarding the models shown in my earlier post, the free-lanced MLW FPA-4 (an old Model Power unit) was based on a photo I had taken of a VIA unit in service. with most of the grabs placed as on the real one. The dual light on the nose door and the icicle breakers on the roof are courtesy of modeller’s licence, and the paint scheme is based on the CNR’s freight scheme for cab units - the prototype originally wore CNR’s passenger scheme, in which the lower body panels were black. Here’s one of the photos which I took of the VIA loco:
The Rail Shop carbon black hopper was built pretty-much as outlined in the instructions, although I added most of the major brake piping components, as they’re fairly visible on a car of this type. The pipe routing was based on a Cal-Scale info sheet, included with their AB brake set, and modified to suit this particular car. The Rail Shop instructions included a good photo of the real car, which was a great aid in lettering the car.
The CNR T-3-a 2-10-2 was built for a friend and was based on an old Akane USRA 2-10-2, much like its prototype was built from an ex-Boston & Albany USRA loco. I worked from a couple of prototype photos and a couple of photos of an older model built by someone else. Here’s the original Akane loco, with the as-yet-unmodified Bachmann tender:
Obviously to model at your level there are a wide variety of resources necessary. Up until now I have not paid too much attention to the resources available on the prototypes. That will need to change.
One thing I can say is that your version of “good enough” and my current version of “good enough” are a long ways apart. I do hope that in the future, once I actually have a layout, that my interests will turn to detailing more accurately. That would seem to be a more logical and rewarding goal than simply buying more RTR.
Used guitar strings are great sources for small wire .009" diameter and up. Often you can find .010" .011" and .012" which are perfect for grabs. Just hit up a guitar shop by you and see if they have any old used guitar strings they wouldn’t mind giving you…most often they will end up in the trash otherwise. [oX)]
