Best material to use in construction of a very large S scale citrus packing shed
OK, got monster of a prototype, the main complex measures 4 X 6 feet. My initial design concept is to use tempered Masonite for the subwalls and perhaps the same for the roof, brace the interior with 1x1 clear lumber and plenty of glue and screws and seal all wood surfaces against moisture. Build it upon a solid foundation (Plywood?) incorporated into the benchwork. Windows and assorted trim are not an issue with me, I can scale jump as needed or scratchbuild. How does my plan gel with the rest of you? Any suggestions or tips welcomed. Before it is suggested, I do intend to build it in sections to keep it managable thus the gorilla concept for durability…
Dave
have you seen the gator foam at micromart http://micromark.com/
its not heavy and very easy to work with
its impervious to weather. not very expensive
K
Gator foam, why didn’t I think of that!! No need to break out the power tools…Just invest in hordes of #11 blades!!! Thanks
