Out of all my locomotives i have to say that my Athearn GP-9 runs the best. All my athearn and atlas locos do very well. i also have a couple of athearn genesis that run well and a couple of bachmann spectrums that also perform well. The only locomotives that give me the worst trouble so far, have been of course Tyco but that was years ago, and Life-like’s Proto 1000 series…chuck
The majority of today’s locomotives are smooth runners and the age old question of “Best running HO locomotive” is basically outdated…ALL manufacturers can produce a lemon or have some bad ones to slip by QC…There is NO exceptions to that rule.
For smoothest running, you just can’t beat the Buehler and Cannon drives on the Stewart locomotives. However, they only carry early, 1st and 2nd generation diesels. For more modern versions, Kato, Atlas, and Proto 2000 would be a great choice.
I have two early diesels made by P2K (Walthers now) and I like how they perform. I would have to say my showpiece, though, in every respect, is the Atlas Gold Series Trainmaster. Wow, oh wow!
I don’t have much in the way of diesels, but of the three I’ve got, I’d say that my Genesis F-3 A/B set is certainly one of the most powerful, smooth and quiet locos I’ve seen. I’m also DC, BTW, and these babies can crawl from tie to tie with the best of them.
I have a mix of mainly EMD F units and I would rate the engines in the following order
Intermountain
Stewart - Kato Drive
Athearn Genesis
Stewart - Stewart Drive
Atlas/Proto
The power pack you use also makes a difference with the running aspects of the engines. I use an old MRC ControlMaster X. It has adjustments for voltage and momentum variances. A great old power pack.
I think my Atlas C425 is best locomotive I own, based against P2K, Bachmann Spectrum, Walthers Trainline, Athearn RTR, and other Atlas’s. It’s a VERY smooth runner and will creep along like it’s barely moving. I paid $65 for it
Of the locos that I have the Proto 2000’s do quite well. On the cheaper side the best runners I have are Athearn BB locos. I have an Athearn F7A that can crawl so slowly you have to put a marker down then look away for a few seconds then look back to see that it actually moved the width of a couple of hairs. About the only thing I don’t like about the BB locos is that they’re a tad noisy. But after a while that noise grows on you.
The majority of my locos are Athearn BB that are up to 45+ years old - and still running!! I have newer Athearns, Atlas, BLI, Walthers Trainline, Rivarossi, and Genisis. The only ones I have that are NOT good runners are a couple of Bachmanns. My [2c]
Think it would be my old BB Athreans that I have alot of. I run DC also haven’t had the time to switch yet to DCC but my PA1 Proto 2000 has it hands down as the best runner.
Out of all my loco’s My (I know i’ll miss spell this) ravvarosa (IDK how to spell it but I know its that brand) runs best but it take a little extra power to get it going. (ok I know that was a steamer as for desil (the two desils I have) I like my athern c44-9w over my bachmann sd40-2
While my proto 2000 SD7s ran very nicely when new and on level ground I’ve come to have a love/hate affair with them. One of the three has developed a problem somewhere in the gear train which chatters or howls. Sigh. And all of them were early-on prohibited from service where they were going down grade with a long train behind them (> 1.5% with more than 10 cars) because the slop in the gear train made them ‘pogo’ (there are two fixes for this - a) disassemble the gear train and shim the worm gears, and b) use a back emf decoder to tame to pogos - but that much back emf makes them ‘buck’ when in a consist).
My best running locomotives are Kato RS-2 and RS2C units. The only flaw I’ve found in them is they don’t have much lateral tracking in their trucks so track which rocks side to side on a curve will easily derail them (persnikity buggers they are). And no pogoing on a down grade with long trains behind them (and no shims or back-emf decoders).
I have a bunch of Athearns new and old and they see a lot of run time. But, with that being said my Proto 2000’s and 1000’s are the best I have. My Athearns need a lot more lubing and care than the PK’s. Except the PK2’s BL2’s that where made in the 80’s I have yet to repair any of my Protos!
My worst pulling Proto is a SD-7, it will only pull 20 or so cars up my 1.5% grade. MY F-3 PK 1000 are great pullers, one F-3 will drag 30 cars. I have 4 and ran out of room before I ran out of power. Proto E-6’s, they are the best pullers I have. One E-6 will drag 45 cars up my grade.
Cost is a round $60.00 each. My F-3 1000’s are Monon and came as powered A&B set at $90.00. E-6’s 2000’s came as a powered A & B dummie Santa Fe War Bonnet for $95.00.
Smoothest DC operation: 1) Atlas Classic RS-1/Kato SD-40/Atlas Master B23-7 2) Stewart/Bowser DS-4-4-1000 3) P2K SD60/ P2K GP-18/ Athearn RTR SD-40 4) Athearn BB GP50/60 (could be better than the P2K’s with more TLC)
If you are considering upgrading to DCC in the future and will be converting your locos this may be of use.
Performance after DCC conversion: 1) Atlas Classic RS-1/ Stewart/Bowser DS-4-4-1000 2)Athearn RTR SD-40 3)P2K SD60/ P2K GP-18 (Started Pogoing on STRAIGHT AND LEVEL track at low speeds - still have not figured out why). The others are not rated because they have not been converted yet.
Quick picks based on my experience (DC versions assumed) :
Budget loco (Around $100 or less): Athearn RTR and ATLAS Classic (if you can find them - got mine at a show)
Midrange loco (Between $100-$200): Bowser/Stewart - Tradition Line, Kato, Atlas Master Series
