What do you do to break in a new locomotive?
Run it just like any other engine i have. Just make sure it is lubricated after about 1 hour of use. It will eventually break it’s self in and run a bit better.
Bob
Generally, speaking, A half, hour in forward,a half,hour in reverse…
Cheers,
Frank
I use to think breaking in a locomotive was needed but not recently.All I did with my last three new engines is I inspect the engine,coupler and trip pin height and after a quick back and forth on my test track the engine is ready for service.
I do the exact same thing.
For about an hour I run it at DIFFERENT speeds both forward and reverse, and I try to give equal time in both directions.
Jarrell
I do what the manufacturer tells me to do, as far as “Break-in”. If no specific instructions are given, I run for one hour in forward and one hour in reverse. I don’t vary speed, as I have the ability to run in a continuous loop with varying grades and feel this does more for the “break-in” procedure.
From what I’ve seen using the above, I would agree, modern RTR locos probably don’t need a “Break-in” excepting I feel more confident in the locomotive, if I follow a "Break-in procedure and the loco passes that procedure.
For at least 15 mins each:
I run it at low speed forward
I run it at high speed reverse
I run it at high speed forward
I run it at low speed backwards
I run it at medium speed forward
adn medium speed backwards.
Then, I do this for 15 mins at least;:
Run at med fwd
then at low reverse
then at high fwd
then med reverse
then low fwd
then high reverse
then low fwd.
THen, I repeat the above second set WITH RR cars in tow.
then lube oil, and filter change for another 3000 miles
I do this so it gets a variety of speeds for break in, and doesn’t get “wound up” at a certain running speed.
Works for me and mine [;)]
[8-|]
Seems pretty simple! I run for 5,000 miles before Oil and Filter, however 3,000 if all in reverse.
Make sure is is properly lubricated 1st,
then
Run it like you stole it![:-,]
Seriously, unless you are talking about some old open frame motored, cast gearbox piece of ancient history, just run it! Slick lubricants + plastic gears+ can motors = stuff that runs til you’re sick of looking at it. 40 years in the hobby, and I haven’t worn one out yet. I’ve upgraded some, I’ve dropped a few, I melted one (don’t ask), but I’ve never worn one out.
I feel it is worthwhile to give steamers a break in period, as there are many moving parts that may not have been properly tightened when assembled at the manufacturer, like: side rods, connecting rods; or, the valve gear. I’ve had the screws holding these items back out, so running in both forward and reverse for a while, I would say is a good idea and would do the same as I previously described, an hour in both directions, then remove and closely inspect the tightness of each screw and re-lubricate and she should be ready to go.
