They are AC units so the cost is probably about the same as other AC units, which cost much more than the DC units. Sorry I have no exact figures, but maybe the GE web site could give you some information. The lack of two traction motors might be a slight reduction, but these units have the special lifting devices for the center axle in each truck that probably adds cost equal to the missing traction motors.
The center axle has mechanical devices operated by air and controlled by the computer that lifts the center axle on startup if more traction is required. This is deactived above 12 mph so it is just for start up only. Interesting to hear them when they are in this mode.
The C4’s have 1100 hp per axle and were purchased for cross country stack service, not drag freight.
The old 500 series B alxe GE’s used to be used on the high speed Z trains much of the time since they had a higher ratio of HP to axle than the C truck GE’s…
The ‘cost’ of these units is the same or less than a comparable DC unit. This was the ‘selling’ feature that GE is offering. GE want to only build AC units. They are wired so that the missing electrical/traction motors can be retrofitted if the customer desires. The ‘lift’ feature does not lift the center idler axle free of the rail(this would put all the weight on the powered axles and exceed the axle loading limits - damaged rail). It lifts the axle enough to ‘load’ the powered axles to the maximum axle loading limit to increase adhesion at low speed. These engine do not generate the same low speed continuous TE as a normal AC GEVO, bu they are better than a DC GEVO. Considering that they cost the same as a DC GEVO - I can understand BNSF’s purchase.
I was not aware that GE might offer these for about the same money as a DC unit. The weight that is lifted off of the center axle is probably about 20% of that axle weight but it does allow the two other axles to gain traction below 12 mph. I don’t think the four axles pull as well as a regular DC unit with six axles at slow speeds but they do better at high speed for stack trains.
There was a GE ad about these locomotives for a time on their web page.
The assumption that GE is desiring to only build AC traction locos may come from several reasons. These assumptions may also apply to EMD especially with their sale to CAT.
Some or all of manufacturing equipment for DC specific parts may be coming to the end of its useful or commercial life. Reducing the demand on that equipment may advoid the need to replace that manufacturing equipment if only replacement DC parts need production.
AC only may speed up allow # of units built to rise?
RRs going only to new AC may also have some items.
Cost.
Lower mtce costs for AC equipment especially traction motors.
Much of the DC overhaul equipment may be reaching the end of useful life so buying new AC specific equipment may make long term sense. Remaining DC equipment use will gradually decrease as DC locos are retired.
Amtrak may be a prime example of DC overhaul equipment wearing out now. The E-60s , then AEM-7DCs have been around a long time. They modified some AEMs to AC reducing DC overhaul equip useage. Acelas and HHP-8 also slowed useage. The overhaul equipment at Beech Grove for all the DC diesels may also be wering out.
Each major RR may be at a different point in overhaul equipment useful life remaining. It may be BNSF has Rather old overhaul equipment?
CN on the other hand may have rather new equipment?
Both GE and EMD would like nothing better than to build all AC traction locomotives now. It would simplify their manufacturing process, and AC traction in locomotives are now a proven, and very reliable technology.
There is simply no economic, and certainly no performance reason to justify new DC traction locomotives now.
DC traction motors are a technology whose time has passed.
The ACs will pull better at low speeds too. At slow speeds, the DCs are going to have thermal limits that the ACs will not. The ACs, being frequency driven, will also have a much higher adhesion factor.
I agree with your comments, but I was talking about the new BNSF C4 4 axle version compared to a six axle DC locomotive. The C4’s have only four traction motors on a C-C truck set and that limits their TE. They do lug better up to their limits. There have some stalls with C4’s on drag trains which they were not designed for. Their primary use should be in high speed stack trains on the Transcon. The orginal GE ad talked about their design and way the BNSF wanted the high horsepower per axle.
That is true, the absolute max should be similar. However, the 4 motor AC will be able to generate higher average TE due to its superior traction control software and frequency drive which allows all the powered axles to always rotate at the same rpm. With DC, once an axle breaks free on on a hard pull, it will try to “run away” from the others. The experience on CSX has been for a given tractive effort required , the ACs will always pull more reliably than the DCs. On a really hard pull, you will run into DC thermal limits at max tractive effort, with AC you will not.
This was a smart move by BNSF. They are getting better locomotives for the same price as an six axle DC.
The ES44C4 is a derivation of the high-tractive-effort ES44ACs that GE has been building for CSXT. Both use the same traction-control software and have traction motors capable of producing 36,000 pounds of tractive effort per motor, adhesion permitting, compared to the 30,000-pound limit of conventional ES44AC motors. If the weight of two traction motors and two axle gears is added to the 416,000-pound nominal weight of a four-motor ES44C4, the resultant total is about 432,000 pounds, which is the nominal weight of a CSXT ES44AC.
Thanks for the clarification and technical information, beaulieu. So, I missed the 300 figure by 20. I guess that isn’t too bad for a half-follower of BNSF.
So, as I understand it …
6600-6624 (25 units in the first order)
6625-6652 (28 additional units added)
6653-6869 (the 227 units in the big order)
[6870-6889] (20 unit slots available for a possible future order)
6890-6899 (10 pre-production Tier 3 test units)
I wonder what BNSF will do when the ES44C4’s reach 7200?
Cajon Pass is kind of home turf for K.P., and he traverses it periodically, but the lack of ES44C4’s in the Pass of late has been disappointing. Once in a while one shows up.
An ES44C4 glides westbound (leftward) almost into the crossovers location known as CAJON
I suspect that with all the gensets, GP22s and other rebuilt four axle units that DC will stay around for a good while, maybe just not on high speed stack trains.
Diesels have never managed to keep my attention for long so this may be a dumb question but, how do I tell the difference between an ES44C and an ES44C4 (without getting close enough to read a builder’s plate if there is one)?
